Computers & Internet Logo
Anonymous Posted on Jun 07, 2011
My problem is that I don't know what its for??? I came across a Westek Wireless Plug-in Receiver Model: RFA-110 but have no idea what it's used for. Can anyone clue me in? Thanks in advance for your help.
guru68
Level 2:
Sergeant:
  • Expert 347 Answers
  • Posted on Jun 07, 2011
guru68
Expert
Level 2:
Sergeant:
Answers
347
Questions
0
Helped
63287
Points
865
  • guru68 Jun 08, 2011
    Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
stalcupster
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 21, 2012
stalcupster
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3119
Points
That is part of a Wireless plug-in Receiver Model RFA-110 sold at most hone depots stores to turn on light remotely. It will run a 10 amp circuit.
Wireless receiver rfa-110 not working
Pull the plastic tab off the battery per the instructions.
I'm not having a problem with my tv or the receiver, but there's a blue like that comes on every now and then on the receiver and I don't know what it means? Any ideas?
life_on_stan,
Our Duo receivers do have a blue light which represents the TV2. When that light is on the TV2 is no longer on a screen saver.
I would need more information on your equipment to provide further assistance.
Tommy Faust
DISH Internet Response Team
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
I WOULD LIKE TO CHANGE THE DEFAULT PASSWORD OF MY WIRELESS ROUTER AND I DON'T KNOW HOW TO DO IT. PLEASE HELP ME.
Since you didn't post the model, i'll just give you a general idea. Access your router, then look for the administration page, then you should change your password from there..
Annoying clicking sound from my right hand speaker when its connected to the wireless receiver, stops if i change sockets or unplug. But is constant when connected or watching movie.
You don't mention any model numbers so specific answers won't be forthcoming just yet.
I'm guessing you're picking up interference (the big downside of wireless technology). I imagine the manual addresses that.
1helpful
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Will not heat up
Did you check for 220 volts to dryer? Power to the dryer is made up of 2 110 volt circuits. If 1 is down it can still run but not heat. Check with voltmeter across 2 outside prongs of plug with it pulled partialy out of socket. BE VERY CAREFUL.
Grand Canyon Tech
Grand Canyon Tech
