SOURCE: how to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
SOURCE: uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
SOURCE: adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
SOURCE: IT RINGS BUT YOU CAN NOT ANSWER THE PHONE EXECT FROM THE BASE
See if in the menu choices there is an option to reset all factory defauts. It seems someone has mistakenly locked out the other to units. Can you still use them as intercoms?
SOURCE: i had a uniden 5.8 cordless phone with 2extra hand
problem solved threw uniden in trash and bought another brand
