Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
SOURCE: Uniden Phone Problems.
You can find the manual here:
http://www.uniden.com/pdf/EXAI3248om.pdf
The information you're looking for is on page 40.
SOURCE: manual for Uniden Exa 1978 cordless phone
Hi
Check this link
http://www.theusermanualsite.com/manuals/mfg/uniden/
thank you
SOURCE: How do I turn off the answering machine on my
To turn the Answering System off, press remote on the handset. The
talk/batt low LED lights green. The current Time and Day Stamp and
number of new messages recorded is announced on the Handset receiver.
Go here to get the complete manual:
http://www.retrevo.com/support/Uniden-EXA915-Telephones-manual/id/471dj482/t/2/
-DB
