You will need to open the dryer and look at the element, if you have a meter you will need to ohm it out, but more then likely the thermal fuse is bad. In order to test, test only after test disconnect the bypass, you will need to bypass the fuse: take the two spaded ends off the thermal fuse and tape them together then turn dryer on if you have heat you will need to replace fuse, can be purchased online. eBay is the cheapest but can be purchase from a appliance sales/repair shop, Tim:
http://www.ehow.com/how_5044534_open-kenmore-dryer-panel.html
http://www.ehow.com/how_6746180_bypass-fuse-kenmore-drying-machine.html
