Work for less than 8 months . Analog captured a edition (Pre. 6.0) died one day...(Xp servipack 1 in Dell Dimension 4400)I don't know why can't switch from Digital edition to analog...a messsage from Xp...reinstal drivers...a hundre of times and nothing...the multimedia driver...callisto looks like try to work but nothing. Any solution.Thank you.maggell
Well. it's a Pinnacle DVD 500 Plus PCI device...Pinnacle can't help to fix this problem...they recomend issues a lot.Like change the IRQ,use the second one(AGP Graphic firts)...donwload the RegCleaner...install Adobe Pre.6.0 firts.etc.But I think...is some component problem in the card. Somebody from Pinnacle-Brazil make a offer for repair...too FAR!!!
So, I miss this card,was good a live and still the DV captured is working is the analog for Realtime Edition the dead side.thank youWell. it's a Pinnacle DVD 500 Plus PCI device...Pinnacle can't help to fix this problem...they recomend issues a lot.Like change the IRQ,use the second one(AGP Graphic firts)...donwload the RegCleaner...install Adobe Pre.6.0 firts.etc.But I think...is some component problem in the card. Somebody from Pinnacle-Brazil make a offer for repair...too FAR!!!
When Avid Corp took over Pinnacle a few years ago, this product seem to disappear. In fact they were begging me for awhile to get one. I almost did too.
I wonder if service pack 2 or 3 messed this thing up? I've seen some complaints on here that are similar to what your experiencing.
There are some new analog capture they have out there now that work with digital a lot better than they did a few years ago.
There is something realy proprietary they did to that thing that can make a mess of things..
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
This system supports ECC and non-ECC Rambus modules. ECC and non-ECC
modules can be mixed but ECC feature will be disabled. Modules must be
installed in pairs. multiple modules - PC800 the max is 2 GBs systems tool...run disc clean up...put a check mark in every box, you don' need anything there as it is all copies you have elsewhere... then defraggment also in system tools. If you really feel like making that ole girl hum, do a complete reinstall using the latest drivers from the dell site. If you use your service tag number it will select the better drivers for your application. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8100&os=WW1&osl=en&catid=&impid= go to this page for drivers (above) select your operating system (2000-ME-XP-Vista). hope this helps you. Please leave rating
Color: Black Part No.USBG-VX3VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
Specifications : Video input : One RCA composite, One S-Video.
Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
Package Contents :
GrabBeeX+ USB 2.0 Audio/Video Grabber
GrabBeeX+ drivers CD
Ulead VideoStudio editing software
User's manual
I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
I had to get a Firewire cable to make this cam work with Vista. I was told Firewire is faster (?) and much better video quality because it is made for loads of data. I can't tell any much of difference from USB, but it does work with Firewire. So, basically try a Firewire cable.
Just trying using a canopus 4.0 for your ACEDvio ..it compatible with your canopus DVstorm and your problem can solve with a correct codect or using edius 4.0 to capture your video
thank you...maggell
It's been awhile since I have seen one of these. Does this device operate off of an external power supply?
