Eclipse AVN5500 Car DVD Player Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check map disc disc/eject displalay open/close
Anonymous
Level 3:
  • Master 670 Answers
  • Posted on May 23, 2011
Anonymous
Master
Level 3:
Answers
670
Questions
0
Helped
159498
Points
1915
Have you tried putting another disc in it? If the same happens on a different disc may mean that there is trouble with the motor. If that's the case it needs to be checked by a local technician to see if a part replacement is necessary.
1helpful
When i turn on my mini hifi component system mhc-gn1300d it shows eject and then standby and it's automatically switch off What should I do please help
If your Mini Hi-Fi component system is displaying an "eject" message and then switching off, it could indicate a problem with the disc tray or the system's eject mechanism. Here are a few things you can try to troubleshoot the problem:
  1. Check for any foreign objects in the disc tray: If there is an object blocking the disc tray or preventing it from closing properly, it can cause the system to display an "eject" message and switch off. Remove any foreign objects from the disc tray and try turning the system on again.
  2. Check for any damage to the disc tray: If the disc tray is damaged or bent, it may not be able to close properly, which can cause the system to display an "eject" message and switch off. If you notice any damage to the disc tray, it may need to be replaced.
  3. Check for any damage to the eject mechanism: If the eject mechanism is damaged or malfunctioning, it may not be able to open and close the disc tray properly, which can cause the system to display an "eject" message and switch off. If you suspect a problem with the eject mechanism, it may need to be repaired or replaced.
  4. Check for any other visible issues: If you don't see any obvious issues with the disc tray or the eject mechanism, there could be another problem causing the system to display an "eject" message and switch off. You may want to try unplugging the system and plugging it back in to see if that resolves the issue, or you can try resetting the system according to the manufacturer's instructions.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the system serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
1helpful
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
2answers
Unable to eject disc using open/close buttons
if your not able to eject the disc using the open close button then try to user a paper clip push the clip in the small paper clip hole provided in your player it'll eject the tray..
if this often happens check with new disc if it still happens try to contact a the samsung for a authorized repair..
hope this was helpful
My Eclipse AVN 62D (AVN 6620)car radio/nav unit has a black (blank) touch screen which will not respond to input from the row of buttons below it or to touch input. The unit has power and the scrreen...
I have a eclipse avn62d and when I tried to plug my iPhone in it went to the "check maps" "open/close display" "eject disc" screen and is stuck on that...what can I do to get anything at all to play again, driving in silence is terrible.
1helpful
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
3answers
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Top Eclipse Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
