SOURCE: i have echo 230 trimmer that runs on idle and wide
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
SOURCE: HEDGE TRIMMER IS EASY TO START AND RUNS GREAT AT
You have two adjustment screws on the carb, one is for adjustment the mix at idle and the other under throttle conditions. You can tune the engine by ear. Refer to your manual for which screw is which. If you don't have it you can figure it out by letting the engine idle and give one of the screws a half turn (CC or CW doesn't matter) if that affects the idle condition readjust that screw back to the original position and proceed to adjust the other screw with the throttle full pressed. You will be able to hear the engine lean out or when it runs too rich, simply listen to the engine for when it starts to rev properly.
Air fuel and gas... It needs all of these
Are the crankshaft seals any good ??? This causes an air leak, leading to the engine not being able to draw in the air/fuel mixture
Check this by spraying carb cleaner into carb. Does it start ???
Did you check for spark ???
Did you set the coil gap ??? .010
Did you check compression ??? Someone mentioned 100psi. Close but most wont run under 90psi. Others need 120psi. Echo's will run under 90psi but not much lower
Did you remove the muffler and check the exhaust side of the piston ??? Scoring will keep it from running but I have seen them run, albeit poorly but still run with major scoring.
Is the spark arrestor still installed ??? Is it plugged ???
Just some of the tests I perform since I am an Echo/Shindaiwa Tech
