That is a sign the battery needs charging or is exhausted or the bios is confused.
Remove the charger, remove the battery and pres the power button three times.
Plug the charger back in and it should work.
Don't forget to load all of the software and drivers!
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
please read and execute the commentaries. God bless you Charging Conventions
charging.
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
An orange blinking light on a motorola headset often signifies that the headset (or possibly the charger) is damaged or defective. If it has been less than a year since your original purchase, you can find out if you can get the headset replaced under Motorola's one year limited warranty here.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
