Computers & Internet Logo
Posted on May 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Graphics problem, internet explorer and online games cannot be open at the same time
Anonymous
Level 3:
  • Master 670 Answers
  • Posted on May 19, 2011
Anonymous
Master
Level 3:
Answers
670
Questions
0
Helped
159493
Points
1915
How many monitors do you have? some online games needs to be run in full screen mode. If you only have one monitor then you would have to switch between the game and the browser.
You can also try running the game in windowed mode if it has the option so you can see them both.
Hope this helps!
I can't play Majong main game, I can play the October special.
Most of the time if a game won't load, the problem is your browser or plug-ins in your browser. The browser or plug-in may be glitching, or not set up properly to run the games.
Usually the fastest way to get playing quickly is to simply open the game page in a different browser than you normally use.
For example, if you normally use Internet Explorer, try opening the game page in Google Chrome or Firefox. If the game works in one browser but not the other, that means you likely have a browser issue.
Browser companies are always updating their code, and sometimes their changes mess up online games. That's why opening the game in another browser solves the problem 90% of the time.
Google not working internet stop working
Method 1 : Reset Internet Explorer
  • Open Internet Explorer.
  • Click on Tools menu (Press "alt" key to active menu bar).
  • Click on "Internet Options". a configuration window you will appear
  • Click on advanced tab.
  • Click on "Reset" Button. You'll get an another box, here check a box named as "Delete Personal Settings", then click on Reset button on it.
Method 2 : Disable Software Rendering. Disable Hardware Acceleration option in IE 9 & IE10
  • Un-check a option named as "use software rendering instead of GPU rendering". it is located under "accelerated graphics".
Method 3 : Disable 3d in "NVIDIA Graphics driver" Disable "stereoscopic 3D" option into "NVIDIA Graphic driver" application. (If you have Nvidia Graphics Drivers & Software, If you don't have the you can leave that step)
  • Open Nvidia software from system tray.
  • Disable the option named as "stereoscopic 3D" from NVIDIA Drivers (NVIDIA driver is a computer Graphics drivers their software runs on system tray. )
Only when I am on farmville..It says I have on internet?
Is your Adobe Flash player up to date ?
Have you tried to clear your cache ?
Are you able to play other games apart from Farmville?
Do you get any error message or error code? Here are a few things that you can try -
a) Check the Internet Connection. Internet games need a good internet speed to buffer and load.
b) Try to open the game on a different browser and a different computer. Check if the issue persists.
c) Close other applications and open windows and then try to load Farmville.
Method -
You need to perform the steps from the article mentioned below-
Troubleshoot problems playing online games using Internet Explorer
http://support.microsoft.com/kb/2528246
Additionally, you may refer the steps by Sandeep Ghatuary from the thread mentioned below-
http://answers.microsoft.com/en-us/ie/forum/ie9-windows_7/unable-to-play-farmville-or-petville/78c5930b-e6ae-47da-9a57-1646f4b2b507?tab=MoreHelp
Note: The Reset Internet Explorer Settings feature might reset security settings or privacy settings that you added to the list of Trusted Sites. The Reset Internet Explorer Settings feature might also reset parental control settings. We recommend that you note these sites before you use the Reset Internet Explorer Settings feature.
Hoping this was helpful
Please rate this answer.
Please rate
General extraction error location ES1
As I understand you are not able to play the games from iwin.
1. Is the issue specific to games from iwin?
2. Are you playing the downloaded version or are you referring to online games?
3. Are you able to play games from other websites?
4. Do you have any third party security program installed on the computer?
5. Are you aware of any changes made to the computer prior to the issue?
If you are using the Internet Explorer from the desktop view, follow the steps to try and run the game in compatibility mode.
a) Open Internet Explorer
b) Press F12
c) Click on Browser mode and click on Internet Explorer 9 or 8.
d) Check if the game runs.
Flash player not loading zygna online game is there anyone help me to fix it
hi there! :) try to clear the cache and cookies it might work! :) here's how: for firefox At the top of the Firefox window, click on the Firefox button and then click Options. Select the Advanced panel. Click on the Network tab. In the Offline Storage section, click Clear Now. for internet explorer 1.On the Internet Explorer Tools menu, click Internet Options. The Internet Options box should open to the General tab. 2.On the General tab, in the Temporary Internet Files section, click the Delete Temporary Internet Files button and Cookies. This will delete all the files that are currently stored in your cache and cookies for google chrome Click the wrench icon on the browser toolbar. Select Tools. Select Clear browsing data. In the dialog that appears, select the checkboxes for the types of information that you want to remove. Use the menu at the top to select the amount of data that you want to delete. Select beginning of time to delete everything. Click Clear browsing data. dont forget to close your browser and open a new one once your computer is done clearing the cache and cookies. hope it works! :)
3helpful
2answers
Internet explorer finds a problem with the web ppage and wont open the game the rooms are there but wont let me into them i have updated my flash player and adobe reader etc
Try This:
How to Reset Internet Explorer settings
By resetting Internet Explorer settings, you return it to the state it was in when it was first installed on your computer. This is useful for troubleshooting problems that might be caused by settings that were changed after installation. When you restore Internet Explorer's default settings, some webpages that rely on previously stored cookies, form data, passwords, or previously installed browser add-ons might not work correctly. Resetting Internet Explorer to its default settings does not delete your favourites, feeds, and a few other personalized settings. See the table below for a complete list of all settings and information about whether they are reset or maintained.
Resetting Internet Explorer's settings is not reversible. After a reset, all previous settings are lost and cannot be recovered. Rather than resetting everything, you might want to reset specific settings or delete your webpage history.
To reset Internet Explorer settings use the following procedure
You need to make sure you have Closed any Internet Explorer or Windows Explorer windows that are currently open.
Open Internet Explorer and Click the Tools button, and then click Internet Options.
1.png Click the Advanced tab, and then click Reset.
2.png In the Reset Internet Explorer Settings dialog box, click Reset.
3.png When Internet Explorer finishes restoring the settings, click Close, and then click OK.Close Internet Explorer.
Your changes will take effect the next time you open Internet Explorer.
Every time I get into a warhawk online game the Internet connection times out. And I have an internet connection cause it works with other games When I create my own game the graphics are incomplete and...
It seems that you need to have a port on your pc or router opened. TCP 10070 to 10080 and UDP 10070 to 10070. Opening port guides can be found on google, but basically get into your router (usually 192.168.1.1), or if your using windows go into the area connection and open properties and then advanced on the TCP/IP connections. Then you need to add these ports. I found this page http://boardsus.playstation.com/t5/PlayStation-Network/What-Port-Can-I-open-so-that-my-ps3-has-a-better-conection-to/m-p/29345454
Lagging
if it is only while during online play then it is your internet speed connection is too slow if it all the time while playing the game wether it be on or offline then your graphics card is not advanced enough to support this game mainly because of the amount of graphics ram on your card try upgrading to a new graphics display card! i hope this helps!
1helpful
Images and photos are blurred on internet
Try this:
1. Click the Tools menu, and then click Internet Options.
2. On the Advanced tab, click Reset.
3. In the Reset Internet Explorer Settings dialog box, click Reset.
4. When Internet Explorer 7 finishes restoring the default settings, click Close, and then click OK two times.
5. Close Internet Explorer 7. The changes take effect the next time that you open Internet Explorer 7.
Problem playing 3d online games
The lag is caused by the grahics card memory. 32 mb is not very much for todays games. I would suggest upgrading to a graphics card with at least 512 mb on it. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
