the brake lights don't light up or the taillights don't light up? the brake lights are brighter than the tailights so the tailights won't show up whenbrakes are applied. if no lights work when brakes are applied then check for a bad ground at the light assembly.
would need to see it ,sorry but ford focus is showing for model and these earlier ones have a starter solonoid in the fuse board and its possible this has failed but dont ask me which one look in the manual and find it then test for current to the relay in case the switch on the back of the ignition lock has failed ,doesnt happen very often with the fords unlike a VW .But ? i have known the relay to fail on this model quite a few times .also check for the small wire that goes to starter motor ,its easy to do on a focus as the starter motor is at the front
The ESP button is an update from VW's older traction control button the ASR, but its still the same thing. It prevents the car
from losing traction so none of your tires will burn out. Its good to
have in the rain, but if you want the car to burn out at a light, press
the button and it turns off traction control. Every time you turn the
car off and then on, traction control will automatically come back on
and you just press the button to turn it off again. The key is actually 2
parts, you can purchase just the remote or just the key portion.
Together is runs about $300. The dealership also offers a vale key which
is about $70, but is only a key and does not have the remote and it
will not unlock the trunk. The dealership charges a lot for the book you
should try eBay first.
