SOURCE: leaking faucet
Hi johnparker,
The dripping is caused by the ceramic cartridge leaking. It is a non servicable part.
Couldn't find the model number listed but here is a Talia schematic.
http://www.grohecatalog.com/product/25596/
The replacement cartridges are list as 4 and 5 in for hot and one for cold. Also consider replacing part #7 it is a seat.
Good Luck and please rate this response, Phil
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
SOURCE: dissassemble danze washerless shower valve
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
Plug the drain of the sink with its stopper to prevent any parts from going down it.
Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
Lift the handle off and remove the cap beneath it.
Firmly grip the exposed cartridge with your hands and pull up to remove it.
