Danze & Single Handle Tub And Shower Faucet  Logo
Anonymous Posted on May 02, 2012
How do I repair a Danze single handle tub and shower faucet which leaks benind wall when water is on but does not leak when is off?
D502157BN
  • Anonymous May 03, 2012
    While in my basement, I recently noticed a leak behind the shower wall,strangely the leak only happens when the water is running and the turn key is in the shower position. Any ideas as to what the problem might be?
lbecker478
Level 2:
  • Expert 86 Answers
  • Posted on May 22, 2014
lbecker478
Expert
Level 2:
Answers
86
Questions
Helped
31066
Points
131
This is caused because its not in the value...its either in the shower head seal or pipe or the tub spout...you have to turn it on and some how watch and see where it is coming from....sometimes you can pull back escushion from shower arm and look with flashlight when it is running and if you see leak where arm is screwed into pipe...unscrew and reseal with teflon tape and tighten...if not you will have to cut wall behind system and watch for area of leak...good luck
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jan 03, 2009
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 23, 2009
SOURCE: Danze D500540BNT Brushed Nickel single handle leaks
only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
Anonymous
  • 146 Answers
  • Posted on Jun 26, 2009
SOURCE: Danze pressure balance single handle shower faucet
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Mike
  • 4383 Answers
  • Posted on Dec 13, 2010
SOURCE: faucet in tub (behind in the wall) is leaking. It
A source leak will never be stopped by putty or any sealer. Remove and replace what is leaking, it will typically only get worse.
mstrmstr
mstrmstr
  • 60 Answers
  • Posted on Dec 29, 2010
SOURCE: I have Danze, single handle
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
New spout leaks does the copper pipe go to the rubber ring or does it have to go by it
Tub spout has an o ring that pipe goes through for seal. So it should go by it.
1helpful
Water leaking from tap when turned off
Hope this helps.
sanray
Top Danze Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danze Home Expert? Answer questions, earn points and help others
