Best debidell
That doesn't sound right. I've definitely made slide shows of 100 slides and more and burned them successfully too. I usually create projects divided into chapters of about 50 photos each, though, for example, my largest project so far: about 460 photos - 5 chapters of 50 photos each on disc1; 4 chapters of 50 photos each and 1 chapter of about 10 photos on disc 2. However, I have also burned projects that only had one chapter (i.e. one slide show icon on my menu page), for example one with 105 photos.
What you're reporting sounds strange. Do you mean that the slides get deleted during the burning process (that it is only missing from the burned disc), or do you mean that the slides get deleted while you're still compiling the show? However, I recommend the following:
1. If you don't mind breaking your slide show up into smaller parts (chapters), create a show containing about 50 slides, then another with 50, etc. For each slide show you would click on "Create slide show" and each would have its own chapter icon on your menu page. These slide shows will then run continuously, the one following the other. The benefit is that you (or the person the project is meant for) can then more easily access a specific area or slide in your project if so prefered, but also, breaking up your project into smaller parts seem to assist the burning process.
2. Contact the technical support team for SlideShow Expressions at individualsoftware.com. They've helped me out in the past and will get into touch with you within 48 hours of stating your case. You have to register your product with them before you can get help (computer and programme particulars, etc.), but it doesn't take all that long and it really is worth trying out. Don't hesitate - it is a FREE service. They can respond via email or even phone.
I've picked up a few pointers along the way when it comes to SlideShow Expressions:
a) Large photos (1MB and more) can disrupt the burning process - a classic symptom being that the burning process stops during the actual writing of the files (step 5?). I have successfully burned projects containing photos of 1MB and more, but often this is the reason why burning might fail or you end up with a defective end product. Don't be afraid to resize your photos. Yes, it takes up valuable time, but experimenting with photo sizes can save a project. I've been using Microsoft Office Picture Manager to resize my photos to about 400 / 500 KB per photo (or even smaller), but in the end you have to see what works for you. Look, if 1MB or larger works for you, go for it. But there really is no visual difference in the end product: I cannot tell that I'm looking at resized photos and nobody else will either. Of course, I like to add a second disc (CD-ROM) to my projects, containing the original photo sizes so family members can use these for printing, etc.
b) One of the things that make SlideShow Expessions so successful, is the fact that you can make quite lenghty projects. This however, may lead to issues resulting in failure to burn correctly (or even at all) to disc. It helps to divide your project into chapters.
c) The option to also archive your photos and music files on the disc is a great feature, but it has been linked to burning failures, especially when your project is very large / your photos are quite large (a and b).
d) When including video clips in your project, be sure not to use files that are very large. The end product may work well on computer, but it may also cause problems when that same disc is viewed on TV, as some DVD players will not be able to handle large video clips.
I hope all of this can be of help. Do contact individualsoftware.com should this issue persist. I wish you all the best.
