Thanks but what does this mean? Do I need to get a new one or can it be fixed???Thanks but what does this mean? Do I need to get a new one or can it be fixed???
You can't post conmments that contain an email address.
You must have blackberry curve 8520 unlock code for verizon network before you can unlock your blackberry. That code can be obtained from verizon or third party sites, both of them will take you some charge for a straight blackberry unlock code, but third party sites more cheaper and quick delivery times rather than network provider.
hi. That also happened in my sony ericsson k800. Remove the front cover then clean the scroll cup. Some times it happens if ur phone contacts splash if that doesnt help remove the battery then live ur phone under sun to dry
You should try these steps. 1) Backup contents of your phone like contacts, messages and other important stuffs 2) Format you phone (Hard Format) 3) Restore the contents.
Sometimes this happens due to unwanted change in system files or some kind of virus attack. Formatting your phone will improve you phone's performance also.
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings:
Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
HI bess elias the number your looking for is in your status . Under options, Go to the wrench icon and the hit the pad and then next you want to scroll down to status. Once you hit the status hi the pad and you show be shown all the numbers you need ,
I'm afraid the track pad has to be replaced. It goes to full bright from dim screen when you touch it. that's because it sense the touch.but can't sense the direction(scrolling).
But, before that, see if a master reset works. Backup everything before that though
How to reset BlackBerry Curve 8520 to factory settings:Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
