There are two nuts up by the blade that will be removed to get blade off also there is a small screw next to the blade itself on the opposite side. You must loosen 2 big nuts then back this small screw off a few turns will be inside a small hole near blade. Once blade chain is loose take nuts off drop blade replace do everything now in reverse.
http://www.fonerbooks.com/laptop_1.htm
there are to many processes to type in so this link will provide details on removing and replacing hard drive in a laptop
hope it helps you
