I think you have an external voltage regulator in that year , ck that first . The easy way to tell if it has an external regulator ,if it has carburated it has an external regulator if its fuel-injected its internal regulator in side the alternator.Have you checked to see how much voltage the charging system is putting out at an idle ? It should be around 13.5 volts to 14.5 volts any less then 12.5 charge light won't go out.
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you
have the battery charged. It can be an indication of a weak battery or a faulty
alternator. If the battery light still on after charging then the problem will
surely be on the alternator itself. If that's the case the alternator should be
replaced to resolve the problem.
You may try to reset it to by removing the positive battery
connector, letting it sit for at least 5mins. then reconnect it again. This
will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
