Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change oil - Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
2strokeJim
Level 3:
  • Master 577 Answers
  • Posted on May 05, 2011
2strokeJim
Master
Level 3:
Answers
577
Questions
0
Helped
292361
Points
1529
Alot of the newer mowers you pull the dipstick and tip it on it's side into a empty anti freeze jug that you cut the side open makes a nice drain for it, or similar contaner, let drain till quits dripping then put upright and add new oil, remember it does'nt take a full quart, so don't overfill or you'll be tipping on side trying to get extra out. Hope I helped You
Why the change engine oil light keep coming on when i start my 2005 buick rendezvous? how can i turn it off?
Did you have the oil changed lately ?
Oil Life Left
Oil life left percentage is based on the information the DIC receives from a class 2 message from the PCM. The DIC displays the current percentage of the GM Oil Life System. When the oil needs changing the change engine oil indicator in the message center turns ON. When the engine oil is changed, reset the oil life left. Refer to GM Oil Life System Resetting in Maintenance and Lubrication.
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL message will come on. Change the engine oil as soon as possible within the next 600 miles (1 000 km). It is possible that, if driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, the engine oil and filter must be changed at least once a year and at this time the system must be reset.
If the system is ever reset accidentally, change the engine oil at 3,000 miles (5 000 km) since last oil change.
How to Reset the Engine Oil Life System
If the vehicle does not have optional Driver Information Center (DIC) , do the following:
Turn the ignition to ON, with the engine off.
Fully press and release the accelerator pedal slowly three times within five seconds.
Turn the key to OFF. If the CHANGE ENGINE OIL message comes back on when you start the vehicle, the Engine Oil Life System has not reset. Repeat the procedure.
If the vehicle has the optional DIC, do the following:
Press the MODE button until the DIC reads OIL LIFE LEFT/HOLD SET TO RESET.
Press and hold the SET button until 100 percent is displayed. You will hear three chimes and the CHANGE ENGINE OIL message will go off.
If the CHANGE ENGINE OIL message comes back on when you start the vehicle the Engine Oil Life System has not reset. Repeat the procedure.
2answers
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
At 28,066 dealer oil change. At 28,778 dealer flushed engine to remove sludge build up and changed oil. At 30,835 miles inspection, dealer flushed engine to clean out sludge and changed oil. At 34,630...
First dealer was NOT doing you any justice. Next oil change run a can of GUNK engine flush let idle 5-10 mins then change Oil & Filter and use a good oil like Castrol or Valvoline 10w-30. You won't have "supposed" sludge build up.
I have a 2002 hyundai santa fe. I want to change the oil filter on it but not the oil itself. I was told that to change the oil filter on this car you have to have a complete oil change. Is this true? I...
neither have i to be honest ,i change oil filter every third oil change on my regular customers cars with a oil change every 6000km or so ,never a problem and i have often changed a filter on some cars without changing teh oil where the metal cannister has started leaking
3helpful
4answers
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
My oil light is on, i have 39 miles on my gsxr 600. do i need an oil change or do i need to put oil in
Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
Change oil light stays on after oil change
Did you also change the filter as well as the oil, and have the system flushed?
If not, do so.
5helpful
3answers
2006 ford exsplorer oil light did not go off after a oil change.
In the owners manual, you will find reset procedures.
I found this for ya, hope it helps!
Please Rate!
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
2answers
No problem, just question on oil change,
I would recommend that you change your oil every 3,000 mile or 3 months which ever come first. This just help you keep a cleaner engine and keeps oil at Peak performance and provide excellent protection against sludge which developes with lack of oil change. Once a year seems too long for an oil change. However between oil changes you can add oil if needed. Good luck and thanks for using FIX YA
105helpful
3answers
2006 Ford Explorer "Oil Change Required" light is still on after changing the oil
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset
OIL LIFE AT XXX%.”
40% and 30%.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
