SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
SOURCE: Looking for manual for Craftsman 917.256552 15HP
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
the belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Testimonial: "Good to know. Thanks for the quick reply."
