Just something to be aware of though if you are using RCA, s-video, or VGA you will not get HD resolutions. Only though component(RGB), DVI, HDMI inputs.Just something to be aware of though if you are using RCA, s-video, or VGA you will not get HD resolutions. Only though component(RGB), DVI, HDMI inputs.
You can't post conmments that contain an email address.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Any of the universal remotes should work. Check their sites on line first to see if they have codes for your TV. I recommend a Logitech Harmony remote that is "activity based" and can control all your electronics with a single remote.
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
