My 93 lesabre turn signals stopped working abruptly no flash and the turn indicator lights in the dash wont even light up i pulled the four ways on and ck all the turn signal lights and they operate in hazard mode i found the 4 way flasher and that clicks in hazard mode i bought a new turn signal switch and that did not change any thing i ckd all the fuses in fuse block and could not find any blown fuses what could be wrong?
The flasher unit for the four ways is separate from the turn signal.
If the rear light is flashing fast means the front light is malfunctioning. Check all wiring from the dash to the light itself. I had one a wire was pinched and had broken
there is a flasher under the dash put your 4 ways on and listen for the tick noise find the flasher unit under dash area driver side there is two one for the 4 ways and 1 for turn signals now that you have found them turn on working signal touch the flasher unit you will feel it pulse and hear the noise when you have the one pulseing on working signal this will need replacing can also be in fuse area have a good day
Your multi-function switch is likely toast and shorting internally. Removing the column shroud and inspecting the wiring will tell you if it's wiring. Given the fact the headlamps work but everything else doesn't suggests multi-function switch.
Sounds like a crossed wiring connection somewhere, if the four-way flashers are turning on the high-beam indicator.
Check all the connectors in the associated wiring harnesses for the instrument panel.
If the lights only come on but dont flash, activate your emergency flasher with the turn signal off. Take a walk around the car and see that all 4 bulbs light up. If not replace the faulty bulb before looking to replace the turn signal flasher. The flasher unit is located under the dash on the drivers side of the vehicle. You will have to remove the panel under the dash to get at it.
