Cars & Trucks Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low coolant light on,resevoir full,has been removed,cleaned,re-installed,no help,does this sensor come off or do you have to buy entire new resevior. this is a duratec 24 valve D.O.H.C.
Jeremy W.
Level 3:
Top Expert:
  • Ford Master 5,332 Answers
  • Posted on Apr 21, 2011
Jeremy W.
Ford Master
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2060510
Points
17799
Try this first. With the reservoir full and the engine running tap the reservoir with a rubber mallet repeatedly. The key word is tap (you can get a little aggressive). try this for about 5 minutes or so. If the light goes out problem solved. More often than not this will work.
If that doesn't work the reservoirs are available aftermarket for about 50 dollars and come with the low coolant sensor. I have installed several of these and most of the time they work just fine. Every once and a while I will get one that doesn't seal up correctly.
I would highly recommend calling your local ford dealer to see if the low coolant sensor is serviceable (i don't think it is) and if not replacing the reservoir with an O.E. one from ford.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jonah Oneal
Level 3:
  • Ford Master 14,092 Answers
Jonah Oneal
Ford Master
Level 3:
Answers
14092
Questions
0
Helped
7242334
Points
44533
YOU CAN REPLACE LOW COOLANT SENSOR ITSELF. WITH OUT REPLACING THE WHOLE EXPANSION RECOVERY TANK.
Low coolant keeps coming on and resevoir is full
Copy and paste the following links one-by-one into your browser:
www.obd-codes.com/p0174
www.obd-codes.com/0401
Cool low light comes on but resevior is full
Generally this is caused by an air bubble aroung the sensor in the resevoir. Use a screwdriver or whatever and tap the resevoir where the sensor is. If that dosent get the light out, it is most likely the sensor.
The coolant light remains on even after the radiator has been replace
have you checked the plug in at the coolant resevoir? if good, have you checked the fuse panel for blown fuses? low coolant light comes on because the sensor n the coolant resevoir tells the computer says there is not enough fluid in your resevior, the clear tank under the hood that connects to the radiator. you may have a bad plug in or a bad resevoir. i suggest you check fluid,,if good ,,check plug in,, if good,,replace resevoir,, hope this helps!!
3helpful
On 1991 dodge stealth on the dash lights I have
yeah its probably a bad sensor in the coolant overflow jug. it thinks you're out of coolant when it goes bad. some cars you can just buy the sensor but most are made into the jug and you have to buy the whole resevoir.
5helpful
2answers
2answers
The coolant light comes on when first started and remains on for the first 10 to 15 minutes of driving. The level is fine so, I have no idea what the problem could be.
Locate and clean the coolant level sensor - located in the coolant top up resevoir.
Check electrical connections to the sensor are in good order.
5helpful
2answers
Low coolant light is on with full radiator
Check the coolant top up reservoir. Low coolant sensor is usually in the overflow/reserve container.
Wash out and clean any dirt or corrosion from the sensor prong.
Refill to correct level with fresh coolant, then recheck alarm operation.
5helpful
Low Coolant light stays on
Check you coolant resevoir. The low coolant switch is located in the resevoir so if it is low on coolant there, the light will come on. If it is full, it could be that the switch is stuck due to gunk build up in the resevoir. Hope this helps you out
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
