Check it out manually with a pressure gauge ,could just be a high resistance or something ,but check with a manual dial gauge and if low check put the oil pump
Testimonial: "thanks."
did this, at temp and idle stays around 10#. what should i do next.
probelm by the sound of it ,if engine doesnt knock or rattle then its the sump off and renew the oil pump ,answering questions on fixya i have noticed that these jeeps do seem to suffer with oil pump problems ,drop the sump if you can and then check the gauze filter on the end of the pump if its clean then renew the oil pump but if its full of black grime which is caused by not changing the oil then give it a good clean and try it again as it wouldnt be the first time i have had this problem with quite a few different makes of car.I always recomend changing oil every 6000miles tops and a oil filter every third oil change and use the cheapest diesel/petrol oil you can buy ,these long life oils do not do a engine a lot of good
