Make sure there is not a lock on the top middle of the touchpad that you can press to toggle the lock/unlock. if so, press it. Otherwise I would try booting up in safe mode and see if the cursor locks.
try to connect external keyboard/mouse. if that work, your input devices went south. did you spill something over? number of model is located at the bottom.
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
Put a new mouse on it. and set it up as it boots up. if you don't like that mouse put the old one back on. it worked great for me, Hope it does for you.
If you are using a PC then check that the mouse is connected properly to the slot. Also check the ball inside the mouse, it happens sometimes when its dirty, clean the ball inside the mouse and also inside the mouse(use a small cloth).
If you mouse is wireless then check the battery in your mouse. It might run out of charge. Also check the button which is used to turn on the mouse. It might be jammed.
If its a touchpad there is no solution that I can think of other than buying a mouse.
I followed the advice of pressing the FN and F7 keys at the same time. It didn't work when the program was fully loaded, but I rebooted and tried again during the rebooting and it worked. I had the frozen cursor on the Travel Mate (Acer) also.
If you are using an external mouse, unplug it and see if it will go with the pad.If it works with the pad then its the exteranal mouse. If you are using the pad you may have to replace the pad or recalibrate it using the pointer device, you can use the tab key to go through to the start menu then use the arrow keys to go to control panel. Hope this helps
