I have the Accurian MP3 Player. The device has been fully charged. When I unplug the player from the adapter. I then turn the player on and I keep getting a message that read "Memory is full at 5MG, must delete some songs", GOOD-BYE!
When I hook up the MP3 player to my laptop and hit the button to sync, so that I can delete all the songs and start over. On the screen of the MP3 player is just a computer and the battery is lit up in green.
Seems to be a charging/discharging issue for the battery. Try using the wall adapter only for charging and wait for it to fully charge before connecting to the computer or any other devices.
Hi.
Please check your battery for wear down. Otherwise keep your power adapter/ charger On and turn on your player ( just to see what will going on).
If still problem your player was damaged internally and need to repair at shop
Regards
I had the same problem. It turns out that my adapter for my Dell Digital Jukebox mp3 player works great. You might be able to order one from Dell. I hope this helps.
Ohhh - you broke the port on the mp3 player itself - must be replaced - cannot be repaired for less than the cost of a new Mp3 player.
The battery can also be charged using an AC adapter (not included) or a car
adapter (not included) and you will be able to play your device while
charging with one of the adapters. The battery will reach approximately 70%
charge in 2.5 hours and full charge in about 3.5 hours.
mine did this also, I charged it and i got to use it one time. after i added a test song it and unplugged it from computer while it was still on, it would not come back on.. somehow i got it to reset, i believe one of the tiny holes near the usb plug is the reset switch , try inserting a safety pin or paper clip and it may turn back on.
wont work
