Unlocking somebody changed my unlock code of nokia 1600 can i find master code of it
I have forgot my security code in my nokia 1600 & my IMEI no. is 356209000501558.Can you give me my master code please.
IMEI: 356209000501558Mastercode: 5526160435 Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Hi, You can use Master rest codes and completely reset your Nokia 1600, thereby removing the security lock. Get the Master reset codes from Unlock-free.com for free of cost!! Hope this helps you!!
Hi, Get Master reset code from any online site and completely reset your Nokia 1600, this removes the security lock. Unlock-free.com is where i got the code for my phone for free of cost. Check it out!!
You can use Master reset code to unlock your Nokia 1600, that is what i did when i forgot my security code. Try Unlock-free.com , they provide Master reset codes for free of cost.
To Unlock the Nokia Mobile from Password/Security lock use Master Reset Code,You can Try Master Reset Code at http://www.mobile-unlocker.com/unlocking-services/rs2wp6/ I unlocked My Nokia 1600 from the Security lock using the Master Reset Code purchased from there at Reliable Price.You can check for Your model mobile in the Master Reset Code availability List.!!!!!!!!!!!
Kindly note that,12345 is the factory master code for nokia.
If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
hi, i can give you the master code but you need to read this first ok. 1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software. 2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone. enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code. Any problems just give me a shout back ok.
same problem forgotten security code
i forget my security code for my 1600, help me, please
359377005017735
356977014105208 i need master code of this
