The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
I recently had a problem where I could not Install win XP on an Hewlett Packard laptop computer. (Hard disk not found) error. I was downgrading the Vista System to Xp. I had to go to the bios setting and disable the sata hard drive setting and this solved my problem. I dont know if it will work for you. Try IBM support if its free!
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS?
To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop.
If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
You can go about this 2 ways. First, if you have, or can get your hands on a copy of Windows xp; Load the windows system, then go to the IBM support site and download your drivers. Then you will be ready to go. Secondly, call IBM support and get a set of recovery cds. You will have to have the information from the stickers that are on the bottom of the pc. I don't remember the exact cost, but as I remember it's about $54-55. Usually takes a couple of days to receive them. Either way that you do it, you're going to wrap up a couple of hours. If you need
any additional information, please feel free to ask. If this information has
assisted you in the resolution of you problem, please return here to give my
assistance an appropriate final rating. If this information has answered your
question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
its oem, you either need IBMs restore cd for your particular laptop (model) or an xp pro (any service pack will do) OEM disk. You can not get the OEM disk at best buy, circuit city target etc those are retail versions and will not work. Newegg.com or frys electronics are your best bet, but by buying it from them you are getting another copy of xp pro, just use the cd with the keycode on your laptop and then you can install xp pro on another pc using the code that came with the disk. MAKE SURE YOU ARE GETTING AN OEM VERSION AND NOT A RETAIL VERSION.
Some technical stuff: For the xp pro disk you MUST have the COA product key available, this is usually on the bottom of your laptop, for IBMs disk you just have to have an IBM WITH an IBM motherboard as without the motherboard it will not work. For example, the motherboard goes out and you replace it with a non ibm board it will only boot for 3-5 times, the ideaa is that this gives you time to get your documents off. This is per Microsoft agreement with ibm and all other Original equipment manufactures this include hp, dell etc.
sorry if this is too technical for you please let me know.
If you can get your hands on a Windows XP cd, it will partition and format the drive for you allowing you to install from scratch. You would then just plug in the license key from the sticker on your laptop. As far as the recovery disk on the original CD, there might be an option on bootup that would have you push an F key to access it. Or you can usually order them online. It's not too hard to get the drivers you need from online so I would just go with any XP disk you can get your hands on. You'll be using your own license so you can even borrow one.
