2007 Volvo XC90 V8 AWD Sport Logo
Posted on Jun 12, 2017
2007 Volvo Xc90 D5: I have a Garmin satnav and a Nokia cellphone, both of which used to work on my Mercedes, using the cigarette lighter socket and a "Y" plug to enable both to be on charge together, or individually. In my recently acquired Volvo however, neither devices accept the charge. Is this because the Volvo cigarette lighter has a timer that prevents continuous connection? How else can I attach the satnav and phone to the car's power system?
Charlie Brown
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 32 Answers
  • Posted on Jun 12, 2017
Charlie Brown
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
32
Questions
0
Helped
10427
Points
84
5 Related Answers
Jason Johnson
  • 1619 Answers
  • Posted on Jul 20, 2009
SOURCE: radio and cigarette lighter not working 1991 mercedes 190e
Spin or replace the fuse as the old aluminum fuses build up corrosion and dont work, or work on and off.
If its an after market radio check by removing unit and checking for fuses in line.
Anonymous
  • 484 Answers
  • Posted on Sep 11, 2009
SOURCE: locate fuse panel for xc90 fuse panel cigarette
Usually call "ACC" or "ACCESSORY"on most fuse blocks. Also sometimes attached to "RADIO" or dash lighting. You can buy a fuse tester inexpensively that you can test the fuses while installed to see which one is blown, thus finding the elusive problem.
Anonymous
  • 9 Answers
  • Posted on Oct 21, 2009
SOURCE: 6720, A011, 112B, 4490, 5F11,1144 - Volvo XC90 -
here is the fault read out page for most volvos http://volvospeed.com/vs_forum/index.ph ... =66705&hl=
hope this works for you if not send email to me [email protected]
Anonymous
  • 1615 Answers
  • Posted on Nov 17, 2009
SOURCE: cigarette lighter does not work in my volvo xc90
I have seen car chargers that would blow the fuse. They were shorted out so look in the fuse box and replace the accessorie fuse and retest
Ironfist109
Iron
  • 3018 Answers
  • Posted on Jun 14, 2011
SOURCE: The cigarette lighter connection no
  • There are two fuses that go to the cigarette lighter. Look for the blown one or replace one and then the other just to make sure.
  • In the passenger compartment fuse box look for -
  1. Fuse F1 - 10Amp - ACC+
  2. Fuse F1A - 10Amp - Batt+
  • Hope this helps and thank you for using FixYa
Regards, Tony
Cigarette lighter sockets in front and back seat don't work in a 2006 Volvo XC90. How can I fix before going to a mechanic; or if fuse/socket is blown? Thanks. Omari
our classmate's mother makes $71 an hour on the internet and she has been unemployed for eleven months.. the previous month her pay was $12616 working on the internet for 3 hours every day. go to www.works69.com
1helpful
Where do I plug in my satnav on Polo Match 2014?
Between the two cup holders is a 12v lighter socket.
Using a 12v lighter socket to usb will solve your problems
https://www.ebay.co.uk/p/?iid=262676908405&&&adgroupid=44594567914&rlsatarget=pla-298926473889&abcId=1088856&adtype=pla&merchantid=115148351&poi=&googleloc=9045169&device=c&campaignid=805978797&crdt=0&chn=ps
1helpful
Is there a horn relay in volvo xc90 d5?
most likely a failure in the horn contact under the steering wheel
there is a carbon button that is grounded oit on a brass insert in the base of the wheel
Volvo xc90 cigarette lighter removal
Console cover snaps up and off revealing 4 screws ahead of the shifter. 2 of them will unscrew and allow you to pull out the radio bezel. Don't disconnect ANY other wire plugs but the lighter wire or you will have a SRS airbag warning light stay on which requires dealer or scanner reset..
2helpful
Volvo cigarette lighter keeps blowing fuse
I had this same problem after buying a used 2008 xc 90 and had replaced the fuses numerous times. I finally called the dealer to see about changing the sockets and the girl that took my call told me not to pul the charger in while the car ignition is on. She told me there is a saftey feature on the volvo that shorts itself out if anything is plugged in while the car is on. We have followed that rule now for the past 3 months and have had no problems with the fuse blowing. Once the charger is plugged in I just leave it plugged in and I can attach my phone/ipod while the car is on and it's fine as long as you don't try to plug the charger into the socket while the car is on. Strange I know but it works!!!
Where is the fuse for the cigarette lighter of an xc90 2006
where are the cigarette lighter fuses for a 06 xc90 volvo
Where is the fuse for the cigarette ligher - volvo xc90 2007
The fuse box is on the left end of the dashboard, see the diagram on the cover for the fuse location.
Maybe, this information can helped, Volvo V70R XC70 XC90 Car Wiring Diagram
Hope helps (remember rated this). Good luck.
3helpful
Cigarette lighter does not work in my volvo xc90
1helpful
2answers
Trying to locate the which fuse controls front dashboard on Volvo
When he pulls off the fuse cover the back usually has a diagram that shows what is for what. Worst case pull em one by one
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
