2002 Mitsubishi Lancer Logo
Posted on Apr 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doors lock when I turn the key in the ignition to on and unlock when I turn it back to off, just started today and unsure of why. How do I stop it from doing this? Mitsiubishi Lancer Cedia Wagon.
Anonymous
Level 2:
New Friend:
  • Expert 126 Answers
  • Posted on Apr 05, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
126
Questions
0
Helped
28746
Points
380
Usaully this is done by the keyfob when u press it to lock the doors,if u take and hold down the keyfob your horn will beep1 time it will lock your doors keep holding it down it should beep again after this unlock your doors this should reset this.
2answers
How to program fob for 2011 chevy malibu
google how to program fob for 2011 chevy malibu for more info
On the Chevy key fob, press and hold the "Unlock" and "Lock" buttons at the same time until you hear the door lock and unlock again. This means you're all set. Re-insert the programmed key back into the ignition to the "On" position to finish the Chevy key fob programming process
2007 Nissan Maxima. Car unlocks, ignition locked.
Because you removed the fob battery and further compounded by the fact you disconnected the vehicle battery, the complete lock system and the anti-theft immobilizer system needs reprogramming. I am undecided whether a locksmith or an electrician is better, but would suspect the auto locksmith.
https://www.google.com/search?q=mobile+auto+locksmith+near+me
https://www.google.com/search?q=mobile+auto+electrician+near+me
The car should always be started with a proper chipped key. The valet key on my car has a chip in its credit card style case. It will start the car if the case is close, or you can give the key to someone just to gain entry to the car and not start it.
1helpful
Kiah sportage 1999 remote wont unlock my ignition to get my motor going,i have changed the battery but still doesnt start,,is there any way to bypass the remote to get my car going.
keys into ignition turn to number 2. press fob. doors lock press again doors unlock. turn ignition back remove key. press fob lock doors wait 5 seconds press fob to open doors. then try ignition again. should work. if not then there is something like a chip missing from the key or the ring reader on the ignition is not working.
2011 Ford Fiesta 5 speed manual base model no key fob ONLY drivers side door lock w key. Mechanism in drivers side door lock not catching not working will not lock or unlock. Electronics inside at console...
LOCKING AND UNLOCKING
You can use the power door lock control or the remote control to lock and unlock your doors and tailgate.See Tailgate Lock.
Power Door Locks
The power door lock control is on the driver and front passenger door panels.
AUnlock.
BLock. Remote Control
You can use the remote control at any time your vehicle is not running.
Unlocking the Vehicle (Two-Stage Unlock)
Press the button to unlock the driver door. Press the button again within three seconds to unlock all doors.The direction indicators flash. The direction indicators flash twice to confirm the change. The unlocking mode applies to the remote control, keyless entry keypad and intelligent access.
Press and hold both the lock and unlock buttons on the remote control for four seconds to disable or enable two-stage unlocking. Disabling two-stage unlocking allows your entire vehicle to unlock with one press of the button.
Intelligent access at the driver door unlocks your entire vehicle when you disable two-stage unlocking.
Locking the Vehicle
Press the button to lock all doors.The direction indicators flash.
Press the button again within three seconds to confirm that all the doors are closed.The doors lock again, the horn sounds and the direction indicators flash if all the doors are closed.
Mislock
If any door is open, or if the hood is open on vehicles with an anti-theft alarm or remote start, the horn sounds twice and the direction indicators do not flash.
Activating Intelligent Access
General Information
You can unlock and lock the vehicle without taking the keys out of your pocket or purse when your intelligent access key is within 3 ft (1 m) of your vehicle. Intelligent access uses a sensor on the back of the door handle for unlocking and a separate sensor on the face of each door handle for locking.
The system does not function if:
  • Your vehicle battery has no charge.
  • The key battery has no charge.
  • The key frequencies are jammed.
Note: The system may not function if the key is close to metal objects or electronic devices, for example keys or a cell phone.
Note: If the system does not function, use the key blade to lock and unlock your vehicle. See Remote Control.
Unlocking Using Intelligent Access
With your intelligent access key within 3 ft (1 m) of your vehicle, touch the unlock sensor on the back of the door handle for a brief period and then pull on the door handle to unlock, being careful to not touch the lock sensor at the same time or pulling the door handle too quickly. The intelligent access system requires a brief delay to authenticate your intelligent access key fob.
Locking Using Intelligent Access
With your intelligent access key within 3 ft (1 m) of your vehicle, touch the outer door handle lock sensor for approximately one second to lock, being careful to not touch the unlock sensor on the back of the door handle at the same time. After locking, you can immediately pull on the door handle to confirm locking occurred without inadvertently unlocking.
Note: Do not use the outside door handle as a roof cargo strap.
At the Electronic Tailgate (If Equipped)
Press the exterior tailgate release button inside of the tailgate handle. The tailgate unlocks and opens. See Electronic Tailgate.
Smart Unlock
This feature helps to prevent you from locking your intelligent access key inside your vehicle's passenger compartment or rear cargo area.
If you leave your key in the ignition, when you open the driver door and lock your vehicle with the power door lock control, the doors lock then unlock.
You can still lock your vehicle with the key in the ignition by:
  • Using the manual lock on the inside of the door.
  • Locking the driver door with a key.
  • Using the keyless entry keypad.
  • Using the lock button on the remote control.
Smart Unlocks for Intelligent Access Keys
When you lock your vehicle using the power door lock control (with the door open, vehicle in park and ignition off), your vehicle searches for an intelligent access key in the passenger compartment after you close the door. If your vehicle finds a key, all of the doors immediately unlock.
In order to override the smart unlock feature and intentionally lock the intelligent access key inside your vehicle, you can lock your vehicle after all doors are closed by using the keyless entry keypad, pressing the lock button on another intelligent access key or touching the locking area on the handle with another intelligent access key in your hand.
When you open one of the front doors and lock your vehicle using the power door lock control, all doors lock then unlock if the ignition is on.
Autolock
Autolock locks all the doors when:
  • All doors are closed.
  • The ignition is on.
  • You shift into any gear putting your vehicle in motion.
  • Your vehicle reaches a speed greater than 12 mph (20 km/h).
Autolock repeats when:
  • You open then close any door while the ignition is on and your vehicle speed is 9 mph (15 km/h) or lower.
Autounlock
Autounlock unlocks all the doors when:
  • The ignition is on, all the doors are closed, and your vehicle has been moving at a speed greater than 12 mph (20 km/h).
  • Your vehicle comes to a stop and you switch the ignition off or to the accessory position.
  • You open the driver door within 10 minutes of switching the ignition off or to accessory.
Note: The doors do not autounlock if you electronically lock your vehicle after you switch the ignition off and before you open the driver door.
Enabling or Disabling Autounlock
You can enable or disable the autounlock feature in the information display or an authorized dealer can do it for you. See General Information.
Illuminated Entry
The interior lamps and select exterior lamps illuminate when you unlock the doors with the remote entry system.
The illuminated entry system turns off the lights if:
  • You press the remote control lock button.
  • After 25 seconds of illumination.
The dome lamp does not turn on if the control is set to the off position.
The lights do not turn off if:
  • You switch them on with the dimmer control.
  • Any door is open.
Battery Saver
The battery saver turns off the interior lamps 30 minutes after you switch off the ignition if a door is open and the dome lamp switch is on. It turns off the interior lamps after 10 minutes if the dome lamp switch is off.
Accessory Mode Battery Saver for Intelligent Access Keys (If Equipped)
If you leave the ignition on after leaving your vehicle, it turns off 15 minutes after you close all of the doors.
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Auto door locks don't work, key stuck in Ignition
If the key is not coming out of the switch, it may be off, but you haven't turned it far enough back that final click to remove the key. Some have a button you have to depress to get the key switch to turn back that final click. That's it.
Can not turn key in ignition to the start position.
sounds like the brake pedal lock out switch or the gear selector switch is out of adjustment.
2answers
How to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
1helpful
3answers
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
29helpful
3answers
2001 BMW 325i - Key no longer unlocking doors.
if you have a bmw 325i 2001 model try this solution:
if you have one key , go on to the next step. if you have more than one key, like two or more than follow this procedure.
step one: unlock the doors with your key and get in and close the doors but do not lock them
step two: put your key into the ignition and turn it but not to start the engine, do this less than 5 seconds
step three: take the key out of the ignition and put it near the shifter. press and hold the unlock button while pressing the lock button 3 times. you have 30 seconds to do this. the doors should lock and unlock automatically signalling that it the key has been reprogrammed. if you have more than one key follow those steps for each one except for step one. remmember you have only 30 seconds for each key. that should help you.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
