SOURCE: My Systor burner isn't burning DVD - R. Everytime
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete hope this helps
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Learn how to set up Time Machine to perform backups, how to restore items (or your entire system) from a backup, how to use existing backups on a new Mac, and more.
Products AffectedTime Machine, Mac OS X 10.6, Time Capsule 802.11n (1st Generation), Mac OS X 10.5
Time Machine lets you automatically back up your entire system in Mac OS X v10.5 and Mac OS X 10.6 or later. Time Machine keeps an up-to-date copy of everything on your Mac--system files, digital photos, music, movies, TV shows, documents, and so forth. You can easily go "back in time" to restore files if you ever need to.PLS OPEN THIS LINK YOU GOT ABOUT THE INFORMATION.
http://download.cnet.com/pdf995-printer-driver/3000-6675_4-10068482.html
if this package is not the
right
http://download.cnet.com/2000-20_4.html
on the home page you should
see a search tab just type in what you are looking for
(be precise)also the
download software finder under that there will be a list place a tick in the
box of any one you want/need
all software windows
software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this
link will provide you with many freeware and share drivers
hope this
helps you
