Usually the light bulb is located in the back upper corner under a protective cover. It should have one or two screws to remove it.
Replacement of the
lamp should be carried out by a qualified appliance repair service. YOUR
SAFETY IS PARAMOUNT! Attempt
this only if you are competent. But here is a basic method if you are
mechanically minded and have electrical safety knowledge. The lamp is sat in a housing and its
position is adjacent to the vent holes that it shines through.
If
you feel confident, disconnect it from the mains power, remove
anything in the cavity.
Remove the microwave cover. Purchasing a
new replacement lamp will be useful as it will give you an idea of
what it looks like. Locate the dead lamp remove the lamp and fit the
new one. Replace the covers. Plug it back in and try the lamp by
opening the door.
Hope this helps.
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
