Computers & Internet Logo
Anonymous Posted on Mar 26, 2011
Can I upgrade CPU to an Intel Core2 Quad processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Mar 27, 2011
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2567101
Points
35672
No, the chipset (865GV) and the socket (478) don't allow it. And since this pc doesn't even have an AGP slot it means that you are forced to use only the miserable integrated video.
Just buy a new pc, this one is completely obsolete.
Controleur audio multimedia
You can enter your computer information here and download your drivers for your specific computer . Rate favorable if this helps you.
Need new motherboard
1) Motherboards are rated by size, and shape, by a Form Factor.
Common Form Factor for motherboards is ATX.
ATX form factor is 12 Inches by 9.6 Inches, or 305mm by 244mm.
(9.6 Inches is about 9 and 9/16ths Inches. -> .625 is 9/16ths of an Inch)
Next in line for common motherboard Form Factors, is the Micro-ATX form factor. 9.6 Inches by 9.6 Inches. (244mm by 244mm)
Using these variables, the next factor that needs to be checked, is if the motherboard has a Socket T processor socket.
Also known as the LGA 775 processor(CPU) socket.
Now you need to find a motherboard, that has a motherboard chipset, that will support the Intel Core2 Quad Q6700.
[FixYa has just undergone site changes. I am not able to post a link, as a direct link; at the moment.
I'll have to ask you to copy the URL (Link), paste it in your address bar (http://), and press the Enter key ]
http://en.wikipedia.org/wiki/Motherboard_form_factor
The following is a list of Intel motherboard chipsets, that support an Intel Core2 Quad Q6700,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Start with the Intel 975X chipset. Scroll down through the various chipsets, and see which ones support Intel Quad Core processors (CPU's)
The following is a list of Nvidia chipsets, that support the Intel Core2 Quad Q6700,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_Intel_processors_3
Start with the 700 series, go to the 900 series.
The following is a list of ATI chipsets, that support the Intel Core2 Quad Q6700,
I wouldn't use a motherboard with a VIA chipset. Just my personal opinion.
You also need to find a motherboard, that will use the current Ram Memory you have. Unless you wish to move up to DDR3 Sdram ram memory, and are not currently using it now.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1853614&CatId=4658
Using DDR2 Sdram ram memory? Then this is one example,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157337
[Just in case; How to Copy and Paste:
Let's use the last link as an example,
Put your mouse cursor on the h, of the http://
Press, and hold the left mouse button down. Slide your mouse across, so the mouse cursor goes across the link. (The link is a URL)
The link is now highlighted in Blue. Hold the CTRL key down, and tap once on the c key. (Small case -> c )
Put your mouse cursor in your address bar. (Starts with http:// at the top of your page)
Press the v key. (Paste key)
Now press the Enter key ]
For additional questions please post in a Comment.
(Unless that is scr-ewed up too, lol!)
Regards,
joecoolvette
Can I upgrade CPU to an Intel Core2 dual processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
7helpful
Hp dc5000 all drivers free download
Please find the link below to help you download the drivers;
click on HP DC5000 drivers
2helpful
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    2helpful
    2answers
    Can I install windows 7 on HP Compaq dc5000?
    If you're currently running Vista there should not be a problem running Windows 7. You can download the Windows 7 upgrade adviser from Microsoft to scan your PC for compatability click here to download it. Cheers from Scott and plz vote.
    3helpful
    I need hp dc5000 driver for windows 7.
    There aren't any, your pc is too old and it can't handle 7 properly so HP didn't bother to issue a driver for it.
    4helpful
    Hp compaq cpu two processor do not have the same operating frequency ranges
    can I upgrade to intel core2 quad in a hp compaq dc5700 small form factor
    4helpful
    I need driver controler ethernet for hp compaq dc5000 sff
    HP Compaq Business Desktop dc5000 series ... All dc5000's come with: Intel 865GV chipset ... Integrated Broadcom NetXtreme Gigabit Ethernet for HP try this link for the driver you require
    http://www.general-search.com/download/controleur-ethernet-hp-compaq-dc5000-sff
    Grand Canyon Tech
    Grand Canyon Tech
