driers that over heat may have the lint filter blocked preventing free air flow
check / clean it regularly
Have an accredited electrician / service agent check ti out
Getting your clothes dryer to work efficiently means hot air and air movement! Check your dryer vent hose. It may be clogged or even plugged. If that is the case then all that damp air isn't getting exhausted.
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
