Hey Mike, I can't find a Sears model #1960 charger, so I don't know the specs on it. If it is a typical old school 2 / 6 amp charger or any other that does not automatically shut off or switch to trickle charging, you may be in trouble in a day or two or longer - depending on the charge rate you picked and the percentage of full charge battery was before you connected it.
I have an LG Thrill 4G. My phone just went thru an issue where it wouldn't charge past 4%. Sometimes, it wouldn't go past 2%, so I had to leave it on the charger ALL the time - or risk it dying, completely.
For days, the only services shown on my battery usage were:
Cell Standby: 33%
Bluetooth: 33%
Phone Idle: 32%
Display: 2%
I replaced the battery with a brand new one - NOTHING changed. Battery still sat around 2-4% for the entire day, while on the charger. So, I started uninstalling apps like crazy - just to see what would happen.
NOTHING. Same thing.
So, I decided to at least install the Facebook app back...and the upgraded version had to be installed - so I did it.
VOILA!!! My phone instantly started charging ...8%...14%...24%...52%...80%...91%...all over a period of about an hour. Just a constant charge going up a few percentage points every few minutes...
...and all of a sudden, started going back down pretty rapidly when it hit 92%. Within maybe 3mins, the charge went from 92% to 78% - and I wasn't using the phone. I was just watching the meter drop 2 percentage points over a period of a few seconds, each time. I decided to quickly turn the phone off at 78% but left it on the charger.
After roughly 5mins, I turned the phone back on, just to see what the charge would be sitting at. WOULDN'T YA KNOW - 3%.
How can battery life go from 78% to 3% - while it's OFF - within a 5min span??? Therefore, my question is: was it really charged to 78% when I turned the phone off? Or was the battery meter being "tricked" by some app that might be installed?
The first battery it did this to was the 1500mah. Used that battery for like 3 days of this before I replaced it. The battery the scenario above JUST happened to is my new 3500mah battery, and it's been giving this 3500mah battery the 3% capacity for a whole day and a half now...
Rechargeable batteries don't like being left in a discharged state for very long and are soon damaged.
If the battery is healthy but discharged it might be demanding more current than the charger and internal circuitry can provide causing the charging process to shut down.
The battery might be so discharged it is effectively open circuit and practically useless though sometimes it is possible to force them to take a charge by applying a much higher voltage (I use a car battery) to the terminals for maybe 2 or 3 seconds. It is a kill or cure thing...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Hi. Always charge your batteries overnight after each use. Do not charge your batteries for days or weeks at a time unless you have a good quality automatic charger.
Most 4 amp chargers, charge the batteries up to approx 28.5 volts, and will maintain this voltage forever if left on. This will eventually shorten the life of the batteries.
The Invacare 8 amp charger is a fully automatic charger. It will take the batteries up to about 28.5 volts, it will hold this voltage for a few hours, and then drop the voltage to 27.6 volts ( 13.8 volts across each battery ). These chargers can be left on for weeks at a time.
Good luck. Neil.
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged.However if the battery charger is unplugged then plugged back in a new charge sequence would start.I lose power at my house about every 6 months or so.Once power is restored a new cycle would start and the charging cycle begins again. Hope this helps and have a great day.
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. If you have only had it for 4 days, is it not under guarantee? Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
It very well could be the charging port. As for getting samsung to repair for free, willnot happen. As long as it lasted through the warranty period they are satisfied with the design
With a bad charge port, You have 3 options.
1. get it repaired, warrant if possible 2. Get a new one 3.Get
an external battery charger and charge battery separate from
phone.Another battery and charger will set you back about 10 dollars on
ebay.
