Computers & Internet Logo
Posted on Mar 23, 2011
I have an Archos 7ob eReader and have downloaded Adobe Digital Editions. I now want to know about down loading the books to my computer for transfer across. Can I download books from Amazon bookstores and if so is there a particular type for eReaders that are not Kindle ones.? Thank you for your help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 10, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
530
Points
0
Easy i had the same problem. download kindle for pc. run all the instructions and then download kindle pc converter which will change the kindle editions into PDF files :) only problem is the kindle pc converter is a trial version and you will eventually have to buy this software. then hook up your archos ebook and copy the books to your ebook folder or the SD card and enjoy your reading
tip
Read Digital Editions Using Adobe Reader
Adobe Digital Editions is ebook reader software from Adobe Systems built using Adobe Flash. You can use it to download and purchase digital content, which can be read both online and offline. Transfer copy-protected eBooks from your personal computer to other computers or devices. Organize your eBooks into a custom library and annotate pages. Digital Editions also supports industry-standard eBook formats, including PDF/A and EPUB.
Ifyou have a couple of eBooks on computer which can be read on Adobe DigitalEditions, buy can't read on Adobe Reader. Maybe your eBooks have DRMprotection. To read Digital Editions using Adobe Reader,
ebookdrm removalmay be able to help you. Following is tutorial about Read Digital EditionsUsing Adobe Reader Step by Step: Step 1: Download and install this DRM Removal.Then run it. Step 2: Click "Input..." to add Adobe Digital Editionsbooks to the software. Step 3: Click "Remove DRM" to removedrm protectionfrom Adobe Digital Editions books.
About Adobe Reader : Adobe Reader is the tool for opening and using AdobePDFs. It shipped with Adobe Acrobat. You can create PDF files on it. Althoughyou can't create PDFs in Reader, you can use Reader to view, print, and managePDFs. After opening a PDF in Reader, you have a variety of tools to help youfind information quickly. In addition, Use the Reader multimedia tools to playvideo and music in a PDF. And if a PDF contains sensitive information, you cansign or certify a document with a digital ID.
on May 27, 2011 • Computers & Internet
2answers
Convert ACSM to EPUB
You just have to install the ACSM Reader Adobe Digital Editions to open acsm with ePub.
http://www.epubor.com/convert-acsm-to-epub.html
I need a step to step guide on how to download a book to my iriver
  • In order to read ePub formatted eBooks on an iRiver Story, you can either SYNC the device with your Borders app or use Adobe Digital Editions. Simply connect your device, select 'Disk Mode' and then click on the 'SYNC' button in the lower-left corner of the Borders app.
  • If you have purchased PDF files, you will need to use Adobe Digital Editions to download and manage these files. Please ensure you have an Adobe ID entered in to Adobe Digital Editions prior to downloading the files fro your Borders eLibrary. You can obtain an Adobe ID here:
https://www.adobe.com/cfusion/membership/index.cfm?nf=1&nl=1&loc=en_us
TO GET YOUR PURCHASED BOOKS FROM YOUR E-LIBRARY INTO ADOBE DIGITAL EDITIONS:
  1. Sign-in to your account on the website using your email address and password. You will see the option at the top of the screen.
  2. Once you have signed-in, please click on 'My E-Library', which is also at the top of the screen.
  3. You will now be able to view your eBook library. On the right of each title in your library, below 'Open eBook' you will see a link 'Download Now (For Adobe Digital Editions users)'. Click on the 'Download Now' text for each book to download it, which will not cost you any further money.
  4. The downloaded file may ask you if you wish to open it with Adobe Digital Editions or save it to your file system.
  5. Please click on 'OPEN'.
  6. The eBook should now appear in your library in the program.
If you experience any problems downloading the eBook in to Adobe Digital Editions, you may need to save the file and then right-click on it and select 'Open With' and then manually select Adobe Digital Editions on the first occasion.
When you connect your iRiver device to the computer, Adobe Digital Editions will ask if you wish to authorise the device. This process is assigning your Adobe ID to the iRiver Story, which will allow you to transfer across your eBooks and then open them on the iRiver Story. Please click on 'authorise device' and then drag-and-drop your eBooks to the device by holding down the left mouse button and releasing it when on the iRiver Story, which will appear as the last item on the list in the left column as 'STORY'.
Loading books into adobe digital editions
There are a few different ways you can add books to your Library with the Adobe Digital Editions program. Once the program loads left click on the down arrow beside the "LIBRARY" menu. In the drop down menu you will find an "Add Item to Library" choice. You would then surf to the directory that holds the books you want to add. You can also open a Widow to the same directory and drag and drop the books from your window to the programs window. You can also go to the numerous websites that support the program (the books must have the "epub" extension) and purchase or download books from those websites. Double clicking any of those files will automatically load the Adobe Digital Editions program as the program sets that default action when you install it on your computer. Once the book is added to your library you will see the cover of the book in your LIBRARY view. Double clicking any of the covers will then load the book and the program will switch to the READING mode for you. In the upper left corner of the program you will see and icon that looks like 3 bookends (LIBRARY mode), and another one that look like an open book (READING mode). This is how you will switch between either adding books or reading the books you have added.
If you have ebooks in other formats there are programs which allow you to change the format of the book to the epub format you need for the Adobe program. Calibre, which you can find at http://calibre-ebook.com/
is an excellent free program which will allow you to reformat books if necessary.
Ereader seems frozen says protected by drm can not read any books i downloaded
Where did you download the books from? If from your public library, then you need to go to Adobe Digital Editions and register your computer and ereader (with the same id). If you bought the books from the Sony Book Store, then I don't know what the issue is.
Your library should have information on what you need to do.
1helpful
3answers
I have a slick ereader er 700-2 that won't sync any of my latest ebooks onto the ereader. How can i fix this?
Hi, this is conrard.
if your reader will not sync with your ebooks. try to use the adobe digital editions (http://www.adobe.com/products/digitaleditions/)
download the app then download the epub/pdf format of the book. Use the ADE to transfer the book(drag&drop the book in the slick reader)
2answers
I can't get my ebook which is in epub to download on my alurtak e
PDF to ePub Converter is a specific software for e-book reading devices users who want to convert PDF files to ePub format so that you can read .epub books offline on Sony Reader, BeBook, IREX Reader, iPhone, iPhone, iPod, iPad, and Nook from Barnes & Noble’s. Want to publish your own books or blog in .epub format? Just download PDF to ePub Converter to create ePub files.
8helpful
I purchased my Sony prs 600 a few hours ago replacing my older Sony reader. I get an error message -474. I cannot download books I have purchased from Sony reader store any suggestions?
The error -474 or -1106 sometimes occurs after an issue with validation or authorization in the Reader (eBook) Library software.
From the Reader (eBook) Store, deauthorize the computer.
Close the Reader (eBook) Library software.
Reopen the Reader (eBook) Library software.
Sign in to the account to authorize the computer again.
Try again to download a book purchased previously from the Reader Store.
If the error still occurs, proceed with the steps below:
Install the Adobe Digital Editions software. Use the installer at http://www.adobe.com/products/digitaleditions.
Setup Assistant will be displayed in the Adobe Digital Editions program.
Click the Authorize button and then the Finished button.
Deauthorize the computer using Adobe Digital Editions
NOTE: Press Ctrl-Shift-D to deauthorize the computer.
Reopen the Reader Library.
Go to the Reader Store and sign in.
You will now be able to download an eBook and transfer it to the Reader device.
Resource 2
If issue persists, deauthorize the computer, then follow the steps below.
Browse to http://www.adobe.com/products/digitaleditions/ and download the software.
please sign in with the Adobe ID and password when prompted .
Now, click on the "Activate" option and close the Adobe Digital Editions Software
Reopen the Reader Library software.
Sign in to the Reader Store.
Please perform the above steps and that should resolve the issue.
2helpful
I have a sony e-reader 505. I tryed to download a book.it gives me error 2027,can you help me,please.
When trying to authorize the computer or the Reader digital book to the Reader Library software, you may get an error such as 2027, 1106, 2029, 2056. Follow this procedure to resolve this issue.
Make sure you the firmware of the Reader digital book is current. Firmware updates are available online through the Drivers & Software link on this page.
Disconnect the Reader digital book from the computer.
Do not unplug the Reader digital book while it is updating.
Connect the Reader digital book to the computer and turn it on.
Open the Reader (eBook) Library software.
First, please connect the Reader to the Computer.
Then, install the Adobe Digital Editions software. Use the installer at http://www.adobe.com/products/digitaleditions .
Please let me know when you finish installing the Adobe Digital Editions software.
Now, please click the Authorize button and then the Finished button.
Grand Canyon Tech
Grand Canyon Tech
