NetGear WNDR3700 Router Logo
A
Anonymous Posted on Mar 22, 2011
I just baught the Netgear WNDR3700 router today and only after 10 minutes after I had it installed it, it started losing connection. Sometimes I can play games online for 30 minutess and sometimes only a few seconds, harder to tell when I'm just surfing, but I think it's the same. Sometimes the losses are quick and I only need to wait a few seconds without doing anything and then I can use my web browser again, usually after re-opening it. But sometimes I need to disconnect the internet from the pc, and then re-connect again. I havn't had to restart the router yet. I thought it might be some problem with my wireless network card, but my sister has just the same issue on her laptop, so I strongly doubt it. Also when I logged into the router from my pc, it automaticly downloaded an update, not sure what it was, but after that I tried to reset the router since I had read it can work better after doing so, but still no luck. I'm on windows 7 64bit. Any good step-by-step guide to fix these connection losses?
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on Mar 22, 2011
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812710
Points
6999
If it is this new I would suggest calling Netgear and have their support help you out. Due to the way their warranty works that would be best. I have a netgear router and hate it. I wish I had taken it back as soon as I had trouble. I also out sourced my problem and keep fooling with it, till it was to late to return it and the warranty ran out. Netgear is the hardest most difficult routers to deal with. May or may not work with AT & T DSL they will not tell you if that is the problem or not. Tell you it's your wireless phone or your neighbors who knows, In other words they do not know what causes these problems. Sorry for your trouble with Netgear.
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Wndr3700 does not get internet through sb5101
you know what lets make this easy and not over think it. power cycle the modem. the modem paired your ip to the PC and now it needs its ARP table cleared so it can give the ip to the router.
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Would like to print a manual for my n-600 wndr3700
You can download and print the manual from the Netgear WEB site.
ftp://downloads.netgear.com/files/WNDR3700_UM_16OCT2009.pdf
My netgear wndr3700 keeps dropping the connection. Both wireless and cabled does the same. Any help would be appreciated.
Hi
Sometime the problem come from the powersupply itself the voltage drop under load causing weird troubles working for a internet provider and sometime we get weird trouble caused by bad powersupply
Just installed Netgear511B. It shows I'm connected
i would go into internet options in explorer and go to connections, then lan settings.verify that auto detect settings is checked, then click ok. restart pc and try ie.
2helpful
I have a wndr3700 netgear router which keeps loosing internet con
you need to upgrade formware on router the reset and reconfigure router
following is the steps to upgrade firmware on router
link for latest firmware
http://kb.netgear.com/app/answers/detail/a_id/13091
A. Open the router page using the following way:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
B. Visit the following link to download the latest firmware.
http://kbserver.netgear.com/prod
C. Please follow the steps to upload the firmware of the router:
1. Open the router page using the steps mentioned above.
2. Under Maintenance, click router Upgrade.
3. Click Browse and locate the upgrade file.
4. Click Upload.
5. Wait for the router to reboot.
6. Click on 'Logout' (at the bottom of the list) from left menu.
7. Reset and reconfigure the router.
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can fix your issue
happy to help
Thanks for using Fixya
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
