Computers & Internet Logo
Posted on Mar 21, 2011
When i play some music or movies i cant do the volume by the f2 f3 f4 or the pause or play and i cant usa the buttons,so plz can anyone help me plz
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
5435
Points
84
Go to the website the model of laptop and select driver-install the driver for hot keys
I need a computer Aires k3 user manual to download
Function Keys
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 • Computers & Internet
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + F4 Mute
2helpful
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
5helpful
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
3helpful
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
1helpful
Yahoo messenger music is paused
when i install yahoo messenger it was playing music very fine. I can't remember what I click and the music is paused. What can I do to unpaused the music?
3helpful
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
2helpful
What are the functions of the keys on the dell 1745. F1, F2, keys with the symbols above them?
Fn + F1 Change Display Device. Fn + F2 Wireless Control Fn + F3 Battery information Fn + F4 Decreases brightness on the integrated display only (not on an external monitor). Fn + F5 Increases brightness on the integrated display only (not on an external monitor). Fn + F6 Keyboard backlit(available only if a backlit keyboard is installed) Fn + F7 Mute Fn + F8 Decrease audio Volume. Fn + F9 Increase audio Volume. Fn + F10 CD Previous - Play previous media file. Fn + F11 CD Play/Pause - If there is Audio CD in system, Media player will play music. Fn + F12 CD Next - Play next media file.
F2 F3 and now F4 error message
F2 is oven temp too high
F3 is open sensor OR thermal fuse
F4 is shorted sensor
1.Check the thermal fuse
2. Check that the sensor is installed properly.
3. install new sensor.
Grand Canyon Tech
Grand Canyon Tech
