SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
SOURCE: what is the gap setting for RJ19LM spark plugs for
mine calls for .035
Testimonial: "Your information that I asked for was right on the money but took to long. I ended up doing some more resurch to find the answer sooner. thanks anyway"
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. [email protected]
