Computers & Internet Logo
Posted on Mar 19, 2011
I need the required codec was not downloaded automatically because the Download codecs automatically check box is not selected in the Option dialog box.
Anonymous
Level 1:
New Friend:
  • Contributor 83 Answers
  • Posted on Mar 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
83
Questions
0
Helped
21551
Points
32
1helpful
6answers
My windows could not play mpeg 4 or mp4 format..does a k lite codec could help?
You may want to install the codec pack from the link below, to ensure you have all the codecs required to run all video formats.
http://www.free-codecs.com/download/k_lite_codec_pack.htm
If this still doesn't help, you may need to reinstall your Windows Media Player (or other media software), and then apply the codec pack again.
G:\COMPRESSED HD VIDS\Part 3.avi could not be imported. The required codec was not downloaded automatically because the Download codecs automatically check box is not selected in the Options dialog box.
Is is likely that you need to download video codecs the best option is to download and install the K-Lite codec pack is include most commonly used codec in one installer.
http://www.free-codecs.com/k_lite_codec_pack_download.htm Download the FULL version of the pack from this page.
2helpful
2answers
While playing back a downloaded movie a dialog warned me about needing AC3 codec directshow 8192 for vista. what do I do?
Hi
if you follow this link it should take you to the codec site go half way down the page and click on the one that you would like
http://www.free-codecs.com/vista_codec_package_download.htm
180helpful
3answers
Codec problem. cant play .AVI files. thanks
I'm sorry that you're having trouble playing your .AVI files. I recommend using GSpot (free download at http://download.cnet.com/GSpot/3000-2248_4-10381198.html) to identify the necessary codec, then search with Google to find and download the missing codec.
Alternatively, I highly recommend the VLC player, which has been able to play everything I've fed it, without issue. It's also a free download (http://www.videolan.org/vlc/).
1helpful
2answers
Find codec
It has built-in codecs. If Gom Player is in need of another codec, it brings you to a wep page where you can download it. If it still can not find the suitable codec, then that means Gom can not play that type of file. For example .mov
1helpful
3answers
Where i can get free codec for my vlc?
Download and install the latest version of VLC Player, all the required and necessary codecs will be automatically installed with it.
You can download it from here (click here).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
2helpful
2answers
Divx plus player can't produce sound of a .mkv file saying that I should install additional codecs (directshow). But how to do this?
The KLite codec pack contains most of the codecs you'll ever need including the audio for .mkv files.
It's free from here If you use the advanced option on install you can select the codecs you require.
2helpful
2answers
That the windows media player is unable to paly some movies it show the message wvc1 codec is required to paly this file.
You need CODECS for some DIVX files.
Use other media players like Media Player Classic instead.
Download from the following link
http://www.free-codecs.com/download/K_lite_codec_pack.htm
I CANT ADD SOME VIDEO CLIPS FROM VEOH TO MOVIE MAKER
Looks like the 1920x1080 is HIDEF video. if your laptop is hidef then you haven't got the codecs for hidef installed and you need to download them.
To do this(if yours is hidef.) goto options and check the download codecs automatically
Olympus WS-200S
try this solution from microsoft:
I can’t play a file that Windows Media Player supports. What should I do?Most likely, a required codec isn't installed on your computer. Typically, Windows Media Player automatically downloads any required codecs from the Internet and installs them. However, this may not happen for the following reasons:
• The necessary codec (typically, a non-Microsoft codec) isn't available on the codec server.
• You have an older version of the Player and your automatic codec-download option isn't enabled.
• The Internet security settings for your browser are set too high.
• You're not connected to the Internet.
If you have an older version of the Player (prior to Windows Media Player 9 Series), you can check your codec download setting by doing the following:
1.
In Windows Media Player, on the Tools menu, click Options, and then click the Player tab.
2.
In the Auto upgrade area, make sure Enable automatic codec download is checked, and specify how often you want the Player to check for updates.
You can change your Internet security settings (if you are logged on as an administrator or a member of the Administrators group) by doing the following:
1.
In Control Panel, open Internet Options.
2.
Click the Security tab, and then click Internet.
3.
In the Security level for this zone area, click Default Level.
If you can’t play the file after completing this procedure, restart your computer, and then try to play the file again.
If you still can’t play the file, try to play another file with the same file name extension. If you can play this file, then there is a problem with the file that you want to play. For more troubleshooting information, see the Windows Media Player Multimedia File Formats Web
Grand Canyon Tech
Grand Canyon Tech
