SOURCE: NEED TO KNOW WHICH WIRE ARE WHAT ON DELPHI TRUCK RADIO
You may wish to consider purchasing a wiring harness that will allow you to plug directly into the vehicle harness without tapping or splicing. Here's a link to one such item: This one appears to be for your vehicle.
http://www.sonicelectronix.com/item_5944_PAC+ADD-GM24.html
Installer.com shows the following color code for the radio and speaker wiring for the 2007 GMC Sierra.
Speakers
White: (LF+)
White/Black: (LF-)
Violet/Black: (RR-)
Violet: (RR+)
Green: LR+
Green/Black: LR-
Gray: RF+
Gray/Black: RF-
Radio
Black: Ground
Red: +12volt Acc Switched
Yellow: +12volt Battery Constant
Blue/White: +12v Remote Output (Amp Turn On)
Red/White: Reverse Light Trigger
Yellow/Black: Parking Break Trigger
Orange/White: Auto Illumination
Blue: Powered Antenna
Orange: Illumination
Brown: Phone Mute (optional)
I would recommend that you verify the speaker wires before doing any splicing.
Attach a speaker to a pair of test probes and leaving the harness in and working, probe the back of each pair as coded above to insure that they really are the correct wires. Most likely you will want to convert the rears to low-level, so start with those. Probe the Violet(+)/Violet Black(-) pair and you should get sound in your test speaker. Likewise, do the Green(+)/Green Black(-) pair.
The only other wire you would need from the stock radio for an external amp would be the blue/white turn-on lead and if your LOC has audio sensing turn-on, you may not even need that. Bring power to your amp directly from the battery (fused according to amp manufacturer recommendations) and find a ground within 3 ft or so of where you intend to mount the amp.
Hope this helps.
SOURCE: stereo wiring diagram
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: 1983 gmc sierra wiring diagram
he can buy the haynes repair manule at autozone it has the diagram in it near the back cost $15.00 plus helpful for later problems
SOURCE: wiring diagram for 2003 gmc sierra (cd player)
be careful computer works with cd player rds system
