When your dishwasher door has a problem, check these:
LatchSpringsHingesDoor seal
Latch
The
latch on many dishwashers is adjustable. If your door is easy to close
but difficult to latch, adjust the latch to let the door close more
easily. If you can't see any way to adjust the latch, yours may be
fixed in a certain position. Check for other reasons for the latching
problem.
If the latch has worn out in a way that makes it
impossible for you to close the door properly, you probably need to
replace the latch.
Springs
Your
dishwasher has two springs that counterbalance the weight of the door.
If either or both of these are broken, the door feels quite heavy and
you need to replace both springs.
Hinges
The
hinges are important to the door closing properly. If they're bent or
deformed, you probably need to replace them. Once bent, only rarely can
they be straightened well enough.
Door seal
If
your dishwasher is new--or if you have just replaced a door seal--the
door may be difficult to latch for a week or two. If the tightness
persists, though, try adjusting the latch, if it's adjustable. If it's
not adjustable, there's probably nothing you can do immediately. But
try running the dishwasher on the highest heat cycle to help the seal
conform to the door. Otherwise, the seal should compress over time.
Goodluck..
I believe these instructions are to replace the door spring, however, I need to replace the spring on the door latch.
I am forwarding you a diagram of the dishwasher. I have replaced part #804 (handle) but can't figure out how to attach the spring on the end which is part #801. Maybe this will help you. Thanks for all of your assistance. Lynn
https://genet.geappliances.com/IPCNet/Di...
I have replaced the door handle on my GE GLD4500N00BB dishwasher. However, I need instructions on how to install the small spring that is attached on the end of the handle part. I am including a link of the diagram page of the dishwasher to help you determine what i am asking. Again, I have replaced part #804 but need to install part #801 (recess/latch door spring). I am NOT needing to know how to replace the door hinge. Thanks for all of your assistance.
I must be using the wrong terminology. The spring is not located at the bottom of the dishwasher on the side of the door. It is located at the top of the door on the door handle. I am not replacing the door hinge or door spring. I am replacing the spring on the door handle.
