It sounds like the flasher relay is stuck closed. It is located under the left side of the dash, to the right side of the steering column. Try replacing that and double check if you recently replaced any bulbs that they have the correct base for the sockets. Sometimes the bulb might look right but the base is slightly different. The correct turn signal bulb for your vehicle is a 2057, and an EL12 or FL12 for the flasher relay.
If you have checked all the bulbs,( sometimes in the rear there are two bulbs), the next thing is the signal flasher. To locate the flasher turn the right blinker on and listen for the flasher clicking, usually under the left side of dash by the steering column.
