SOURCE: i could not control my rc helicopter
Please describe your problem in more detail. Are you able to get lift? If it isn't doing anything at all then there are two things to consider:
1.) This model is known to show a full charge when in fact the battery is receiving no charge at all. Contact the manufacturer for assistance.
2.) There's a safety feature that won't allow the motor to engage until the gyro is locked. Be sure to power on the remote first then the helicopter.
If you are getting lift but can't keep it steady then you may have a balance bar issue. If you've encountered a crash or two then this is very likely.
You may want to consider joining RCdiscuss.com. They have an extensive network of RC enthusiasts with valuable knowledge and resources.
SOURCE: hi my helicopter is 9053 , my helicopter working
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
SOURCE: remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
SOURCE: Just bought a 9053 helicopter.
did you put all 8 of the batteries in it? it takes 8 AA batteries.
SOURCE: rc 3 channel apache helicopter how to replace
Cut the balance bar off until the pins are exposed. Use some pliers and squeeze the pin out and then put the new balance bar back on and put the pin back in.
I did it this way without the tool kit, my balance bar was already broken so it wasn't an issue to cut it. It worked for me, I am flying it right now.
