Check the wire for any cuts, burns or kinks. You may have a short in the wire or inside the toaster (two wires are touching or arcing causing the breaker to trip).
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch since it can not be repaired
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
We had the same problem. I took off the bottom plate, cleaned the toaster, reseated all of the connectors on the heating plates, timer, and switch, and the toaster started working again. Only one connector was slightly loose (but it was still connected with decent contact). I am not sure what fixed it. If that did not work, my next step was to purchase replacement parts online and swap out the switch, timer, and heating plates (in that order). We have an older model than yours, but I suspect that the parts are similar. The parts all look very easy to replace. These units are intended to be repaired and not replaced.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
The timer switch is likely bad. Small convection ovens are notorious for this problem and switches may be difficult to find. Try smallapplianceparts.com or search "small appliance parts" for a few places that sell parts. You will need the make and model # of your oven.
You may have awire that has burned off or the control switch is bad. You can get to their site by typing in "dualit" under google and you will get a lot of information and the web site.
Buy and fit a new timer switch.6 screws to remove bottom cover, pull the knob off and 2 screws hidden by the knob will be revealed, these hold the timer in. Make sure you put the wires onto the new switch in the same place you took them from.
