Yes. As long as it's an atwood 6 gal., the opening should be same dimensions. Keep in mind that you will need to supply hydro to water heater in order to operate it on electric, as well as switch etc. For electronic ignition of gas, you will need to supply a 12 VDC source, and switch as well.
Have you tried it with both (hot rod and Gas ) turned on at same time? Is tank well insulated? (looking from behind tank.) Does temperature drop off quickly, or gradually? Did it supply hot water better before, or this is first time you really measured it out? Need to keep in mind that as hot goes out the top fitting to hot lines, cold is coming in the bottom fitting and beginning to mix with hot, which obvioulsy will cause hot to gradually become warm as it enters. 2 gallons out hot tap, 2 gals., at bottom of tank, then mixing as it flows in usually equals, about 2 gal or less of warm, then cold again. Get many complaints of only enough for a short shower when they have 6 gal tank. You can try adjusting temperature up a little to see if it helps. Keep an eye on pressure relief valve dripping excessively as well as shut pump off for 20min-30 min, then turn it back on before touching any taps, to see if it cycles at all, indicating a leak in the system. If pump doesn't cycle when turned back on, no leaks.
Most electronic ignition models only show the red light if there is a problem, (did not ignite) for one reason or another. To start with, make sure your propane is on, and you have a good flame at stove top burner, just to be sure the water heater is getting propane, and all air is bled from the line, which may cause water heater to go into check. (red light) If it does, shut switch off, and retry. Let me know what happens. As far as pressure relief opening and emptying the water heater, and your sure it's not a faulty pressure relief valve, then there's 2 things to start with checking. 1st, does the water seem extremely hot, thus a possible faulty thermostat &/or ECO . Secondly, if the incoming water pressure is too high, that will also cause it to leak bad. Try installing a pressure regulator (usually 40 psi.) at your hose connection. Let me know what you find.
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Your statement is: You ran out of oil,so got more oil in tank.blead the lines.but now you cant get pilot to start
Every oil burner I ever worked on had a type of spark ignition. No standing pilot. If this is the case for you then the only reason it won't turn on is that the lines weren't properly bled. It only takes a little bubble to ruin the day. Don't be afraid to blead lots of oil, you should be catching it anyway to put back in the tank.
Feel free contact me again! Please give me a rating here at fixya.com before you sign off Thank you, Harvey your Master Plumber
