1-the video must be in Camera Album
u can send it via Bluetooth as u send images in Camera Album 2- no edit photo option in Yendo 3- one option is available in Yendo : Clear Entry all missed and dialed and answered ; no option for deleting one dial or missed or answered
Hello, Its easy. Just go to that call log. For instance, you want to delete XYZ's number from the received calls log, go to you recieved calls, scroll to XYZ, select 'options'. In the options, select 'delete'. You would be asked if you actually want to delete the number XYZ from the received calls log. Selecting 'yes' deletes the number. You can do the same for your dialled and missed calls.
Apple does not allow you to delete individual dialed or received numbers in your call history.
It is possible however, if you jailbreak your iPhone. For instructions on how to do this, visit this link
In Motorola, L6, we cant see the missed calls separately. they will be shown along with the received calls.
we cant delete only the missed calls at once..
we can manually delete them by this process as all know..
Press UP navigation key, it opens the received calls menu,
if you see a Tick mark beside a number or name, it represents a received cal,
it you just see the number or name without a Tick mark, it represents a missed call..
you can delete them by selecting options and delete..
it is probably four zeros 0000 give that a try, it will ask for a code before you delete a lot of things just like most cell phones, if that doesnt work try the last four digits of your phone number
Clear All under the Dialed calls and Received calls and Missed calls menu to create new space.The phone should clear itself one number at a time when the memory is full but some don't.If you don't need all those numbers in there--get rid of them--delete all. Good Luck.
How do I view the numbers of calls made or received?
You
can view the last ten calls that have been placed and the last ten
calls which have been received in the Recent Calls option menu.
Press the Menu, Recent Calls and press the right soft key to select.
To view the calls you have received scroll to Received Calls and press the right soft key to select.
To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
Once
in the Received or Dialed calls you can get more information such as
the time the phone call was received/dialed by highlighting the call
you want to view, and press the right soft key to view.
Scroll down to view all the available information.
In
order to delete a received, or dialed call simply highlight the call
you want to delete, press Menu and then select Delete. You can delete
all the calls in the chosen section by selecting Delete All instead of
just delete.
