Olympus FE-280 Digital Camera Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When connecting the FE 280 to my imac OS X 10.6.6 the iphoto opens but only recognizes the memory, and not the xD card, so no photos on the card can be transferred to iphoto. does anyone know how to remedy this? thanks!
Anonymous
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Mar 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
64
Questions
Helped
15830
Points
198
Try removing the memory card from the camera and making sure its not locked (there should be a slider switch).
Hope this helps.
J.Sper
Imac won't recognize camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
In olympus fe 280 when i have placed the xd in the camera and turn on the camera then it displayed two options either to clean up or format then i have chosed format then it displayed after some time like...
A camera memory card should always be formatted IN the camera.
Do not format camera memory cards in a computer card reader.
If the card is formatted in the camera and after that the same error pops up,
you should replace the memory card and recheck.
2answers
I cant the SDHC card to fit in slot.
It's not supposed to. The FE-280 uses xD cards, not SDHC cards.
13helpful
5answers
Mac won't recognise canon drive
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to a Windows computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
What memory cards are compatible with olympus fe 280
The camera is compatible with xD memory cards, up to 2GB.
Good Luck!!
Thanks
I'm needing a driver for my FE-280
I went to Olymbus website to find the driver for the FE-280 Digital camera and it states, no software availble at this time.
They show the camera on the website and I know there is a driver for it, but they are not supplying the consumer with it. Bad choice for Olympus.
I have given you some information and links below:
http://www.olympusamerica.com/files/FE-280%20Instruction%20Manual.pdf
This is the manual for your camera.
Go page 45 at the very bottom. Using a New Card
The FE-280 does not recognize my memory card. What can I do?
First, refer to the xD-Picture Card™ Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
The FE-280 may not recognize non-Olympus brand media or a card that has been formatted on another device, such as a card reader or personal computer. As a general rule, xD-Picture Card media should only be formatted in the camera. Card readers should only be used to copy files from the memory card to an external device.
You may be able to use the card if you format it in the camera.
Warning: Formatting a media card will delete all content on the card.
When I put an xD-Picture Card™ flash memory card into my camera and turn it on, I get a “Card Error” message. What can I do?
This message occurs when the camera is unable to recognize the memory card or when an attempt to format a card fails.
If you see this message after inserting a brand new card, refer to the xD-Picture Card Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
If the card is supported, it may need to be cleaned. Wipe the gold contacts of the card with alcohol using a soft cloth or tissue. When the contacts are dry, insert the card and turn the camera on.
If the Card Error message still appears, remove the card and insert a different supported card into the camera. If the camera reads the second card, then the camera is working properly and the problem lies with the original card.
If you receive this error message after a failed attempt to format the memory card, the card may be defective. For assistance, contact Olympus’ Customer Service and Repair Center using any of the following methods:
Phone: 800-622-6372
http://www.olympusamerica.com/cpg_section/OM_UpdateSoftware.asp
This is about updating the olympus Master Software.
If I can do anything else for you let me know
READ ERROR
the photo was not recognize when you took itthats way it would say read error. no way to retrieve thos pics...sorry..
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
