You sheared the timing key. Remove top cover to engine, Remove flywheel bolt, Remove flywheel, Timing key is between flywheel and crankshaft. If timing key sheared or damaged in any way REPLACE. Put back together. Good luck.
If you are talking about the front foot peg. Take the screw that holds the peg to the mount out. Inside the mount you will see an allen that tightens the mount to the shaft you will need to tighten this allen. Then put the peg back on and your done.
I have the same problem with my Roadking except it wasnt dropped. I did a full alignment of rear tire to engine, aligned the rear tire to front tire, aligned the engine and replaced the front motor mount. Nobody seems to have an answer, that I've talked to anyway. If you find a cure let me know, If I find one I'll let you know.
