i wiped all my pc and no sounds comin out wen i play mp3 and videos what do i do i fix this problemi wiped all my pc and no sounds comin out wen i play mp3 and videos what do i do i fix this problem
i have just had a new mother board put in i put sound dics in but istill cant get any sound it says my device is working properlyi have just had a new mother board put in i put sound dics in but istill cant get any sound it says my device is working properly
You can't post conmments that contain an email address.
You need to know what audio device is installed on the motherboard. Only then you can try the manufacturers website and download the appropriate driver software.
According to me, you are using windows xp as there won't be any problem with windows vista.
The sound card you are using is high definition audio.so you need to download Microsoft UAA Bus Controller Software.Install this first and installed the driver for windows xp.
here is the link for Microsoft UAA Bus Controller Software
This seems to be a drivers related problem. I guess you are running Windows XP on this laptop. Actually this notebook is not officially designed to work on Windows XP, however
there are some unofficial drivers available for windows XP, you may try
downloading the sound drivers from: http://sites.google.com/site/sriksang/software/drivers
I'd recommend to install all the drivers from this page. In case the drivers on this site do not work, let me know I shall provide you other links to the drivers.
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in my pc.from where n what driver to install in window xp for free.kindly advice n thanks.
You should first install and run a program such as PC Wizard. Look for all the information about the sound chip. then go to driver-downloads.com and hunt for your sound driver.
Hi dang4g, I gather you have the current needed sound max driver software? Please open control panel, than open Add/ remove programs. Un-install any previous sound driver software listed. Next open the System icon. Click hardware tab, than click the device manager button. Scroll down to Sound, audio and game controller. Find the yellow ! point. Right click it once & left click once update driver. Windows hardware wizard will open.
Click not at this time & click next. Click install from a list or specific location, than click next. In the next window click browse button. Go find where you have stored your sound max driver software. Choose the correct folder & click next. Your sound driver software should install. Re-start the PC when finished. Check windows updates for a possible update.
I can't find the specs on your board..but try installing or downloading the audio drivers for you board model if you haven't already. Use the original disk if you have it, or do a search for the audio or sound drivers for your type motherboard. After you install the software and reboot, if an audio device is present it should find and install it.
