Computers & Internet Logo
Posted on Jul 28, 2008
HP Desktop Does Not Turn On
I turned off my HP desktop computer and it will not start up again. It is only 1 1/2 years old.
Anonymous
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Jul 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
6
Helped
1440
Points
52
I think u have os prblm.
2answers
Hp pavillion screen is on but screen is dark and keyboard Num lock light is on
If it's a laptop, you can plug in a monitor to see if you can get a signal there. That might tell whether the problem is the graphics card or the screen. There's a Fn/Fkey combination that turns signal on to both monitors; you may need to press that combination to use the monitor.
My laptop went into hibernation on its own and now the laptop will not power up. I thought it was a battery problem so I got a new one. The laptop worked for about an hour and then went into hibernation...
running the DEAD OS called XP are you? the virus magnet?
why not turn hibernation off first.
here are the firsts list ,
1: new RTC coin cell installed in laptop (tiny battery is first)
NO cell last 15 year old, why run this battery?????????????
very very unwise
2: park the huge new battery on the shelf till PC runs right again.
3: now run on AC power, this must work or the pack is bad (99%?)
4: ok it runs now, go to control panel and turn off hibernate.
CP + power, turn it all off.
now the dead thing,
do the HP long reset posted at HP 1,000,000 times.
  1. big battery out
  2. ac pack unplugged. from PC
  3. push power button for 10 second
  4. release.
this resets hibernate , and other oddities.
Windows fefuses to recognize and open programs on my computer
THis is happening when the program that patronize the shortcut is no longer existent in the system ...or the location was changed ...Just delete all short cuts that does that ...and make new ones from the start /all programs ..or for programs installed in a different director (folder) and not in C/program files.. just go to the installation location and make a new short cut..
If my computer and my documents ...and the other original windows desktop icons make the same ...just delete them ..than ..right click on desktop ...choose properties..than desktop ...here you will find customize desktop ...and in there just tick all cases for icons you want on desktop ...This action will place again the original icons on desktop ..For the rest just make new shortcuts from the original execution of the program ...
Computer won't turn on, and it used to start fine.
Check on the back of the computer next to the power supply and see if the little switch has been turned off. Just switch it and try again.
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
2answers
HP DESKTOP COMPUTER
If computer is not powering on then open u r cpu and check the SMPS i.e Switch mode power supply which converts AC to DC it gives a output of 5v & 12v in that the 20 pin or 24 pin connector which is connected to the mother board remove that and short the wires Green and Black and make sure to remove all the power connectors i.e,hard disk,Cdrom or cd writer or DVD writer or any other device and one more connecto which is a four pin connector which is connected to the mother board please remove and test the 20 or 24 pin connector by shorting green and black and behind the smps u have a power cord of ac 220v just plug it and switch on if smps fan rotates that means it's fine then the problem willbe on the mother board just try this
HP DESKTOP
check all connections at the back of the computer if all is plugged in properly
2answers
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. [email protected]
HP Media Center Desktop w/XP
Why would you want to connect to Windows? Yecch. Go to OSNews.com and check around for an interesting OS and filesystem combination.
Still, I'd chalk it up to your having plugged another bootable volume into the machine (e.g. a CD ROM) or otherwise changing the setup from what you brought to GeekSquad. Honestly, you've described the problem circumstances quite poorly. Does it not beep before booting -any- OS?
Grand Canyon Tech
Grand Canyon Tech
