Tip & How-To about Mozilla Firefox
Use about:config to either edit of toggle these settings, if you need to add any preferences
TRUE/FALSE => BOOLEAN
NUMBER => INTEGER
TEXT => STRING
browser.cache.disk.capacity » 150000
browser.cache.offline.capacity » 20480
browser.download.manager.closeWhenDone » true
browser.search.openintab » true
browser.tabs.loadDivertedInBackground » true
browser.tabs.opentabfor.middleclick » false
browser.urlbar.hideGoButton » true
browser.urlbar.maxRichResults » 5
zoom.maxPercent » 400
content.notify.backoffcount » 5
plugin.expose_full_path » true
ui.submenuDelay » 0
nglayout.initialpaint.delay » 0
content.max.tokenizing.time » 2250000
content.notify.interval » 750000
content.notify.ontimer » true
content.switch.threshold" » 750000
browser.cache.memory.capacity » 65536
network.http.pipelining » true
network.http.proxy.pipelining » true
network.http.max-connections » 40
network.http.max-connections-per-server » 16
network.http.max-persistent-connections-per-server » 16 ( slower DSL =6)
network.http.max-persistent-connections-per-proxy » 16 ( slower DSL =8)
network.http.pipelining.maxrequests » 8 (max possible = 30)
There is an experimental XPI addon called Tweak Network that will take care of the http.pipelining all will be saved in the prefs.js file in your unique profile, its a good idea to make a backup of this before you start, you will find this in a hidden folder in your application data under your documents.
There are the other settings using this add-on's you can also easily go back from Power Settings to Default Settings really easily this way.
